Drill presses. Why didn't anybody tell me?!
Started by SonicVI, February 21, 2009, 02:43:14 PM
SonicVI
I have seen the light!  No more misshapen or imperfectly placed holes.  The Dremel workstation is especially awesome.  I used to prill my pcb's by just holding the dremel in my hand. I thought using the press might make it go a bit slower, but it actually made it go quicker and more accurately without ever hitting the pads with the tip of the chuck. I can also turn it 90 degrees, put in a cutting wheel and cut copperclad like a table saw. Highly recommended Dremel accessory.
Solidhex
Nitefly182
My drill press is the most useful gift I have ever received.
jefe
I picked up the same Ryobi press at Home Depot about a year ago. Love it.
Andi
Quote from: Solidhex on February 21, 2009, 03:03:32 PMnow you want to get a unibit!
I used to use a Unibit, but recently switched to some decent TiN coated individual bits and haven't looked back.
Recently I am possessed of a great joy when drilling.
The Iron Chef
ok! Good tool to have but let me caution you as someone with +30 years in a machine shop:
The drill press is the most dangerous tool in the shop. Workpieces grab and spin faster than you can imagine.  Do yourself a favor and buy a small hand vice to  hold most of your workpieces.  dont meen to rain on your parade.
hth
-Keith
-Keith
I build stuff everyday.
Cliff Schecht
QuoteDrill presses. Why didn't anybody tell me?!
You never asked!
:P
I've been blathering that for years.
Life begins when you get a drill press.  :icon_biggrin:
iaresee
I've almost splurged on a drill press a couple of times in the past year. But then I talk myself out of it. I'll drill a couple of enclosures...half a dozen holes...and then...what? It'll collect dust? What else can I do with a drill press? Help me justify the purchase!  :)
Quote from: iaresee on February 21, 2009, 07:50:58 PM
It's a mental thing I guess. I see a tool as an unending stream of possibilities, not a means to a limited end. A tool is a door into technologies you have not yet thought of.
Barcode80
i use my full size drill press to drill pcbs as well. plus, once you have the appropriate tools to do things, you will do those things much more often than you imagined.
Cardboard Tube Samurai
Quote from: The Iron Chef on February 21, 2009, 05:18:03 PM
hth
-Keith
Yes, I found out the hard way about two weeks ago what can happen if you're using a drill press whilst tired. Thankfully there were no major injuries but it sure woke me up!
Outlaws
#12
You can let it sit there until one day you think to yourself, "hey, I can use the drill press for this."
The only thing more satisfying than building or fixing things, is having the right tool when you need it.
hth
-Keith
I guess.  Right now my vote is for the handheld 1/2" electric drill that shattered a bone in my hand, and almost broke my wrist.
Andi
You can put drum sanders on 'em. And safety planes.
Der Groovemeister
hth
-Keith
+1 on the hand vice! I nearly broke a couple of fingers before i started using it. :o :icon_eek:
Use one! Do it!
"What do you mean, dynamics? I'm already playing as loud as i can!"
If you have a drill press, why don't you have one of these?
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=36221
It has almost completely relieved my frustrations with the DP slowing me down because I have to clamp things down. Very quick, very easy, very cheap. What else do you want?
SonicVI
#16
I do have a clamp. I'll have to check out the harbor freight one, they have a retail store in Houston.    When using a hand drill I'd do it on the floor and hold the boxes between my feet to keep them in place. :)  And yeah. I'm gonna have to get a Unibit. Regular bits are too long for taller enclosures with only a 10" press.
drewl
I just took it for granted everyone had a drill press at work :icon_wink:
SonicVI
