I need your help with a neovibe.
Started by Zedmin_fx, February 22, 2009, 11:59:11 AM
Zedmin_fx
Well I was sent a neo to debug, after fixing a cap that the guy had oriented incorrectly, swapping a few other things and rewireing it , it now is  working  but the lfo bleeds thu when the neo is switched off. so the mission is to remove the lfo bleeding and ad a led for on off.
1.What does it do, not do, and sound like?  it turns on and works fine just has the problem with the lfo.
2.Name of the circuit = neo_vibe
3.Source of the circuit (URL of schematic or project) = http://www.generalguitargadgets.com/pdf/neovibeupdate.pdf
4.Any modifications to the circuit?  No
5.Any parts substitutions? No
6.Positive ground to negative ground conversion? dunno
Now, using the original schematic as a reference for which part is which (that is, which transistor is Q1, Q2, etc. and which IC is IC1, IC2, C1, and so on) measure and list the voltage on each pin of every transistor . Just keep the black lead on ground, and touch the pointed end of the red probe to each one in turn. Report the voltages as follows:
Q1
C =2.1
B =1
E =1
Q2
C=4.2
B= 2.1
E= 1.5
Q3
C=11
B=4.2
E=3.7
Q4
C= 14.9
B=4.2
E=4.2
Q5
c=11.2
B=4.2
E=3.7
Q6
C=14.9
B=4.2
E=4.3
Q7
C=11.2
B=4.3
E=3.7
Q8
C=15
B=4.2
E=4.3
Q9
C=11.2
B=4.3
E=3.7
Q10
C=15
B=5.4
E5.4
Q11
C= 23.3
B=11
E=14
Q12
C=23.4
B=12
E=13.8
Q13
C=20
B=4.3
E=4.8
kurtlives
What type of bypass switching did you use?
Input grounded when bypassed is what I used when I built a Vibe and I have no bleeding.
Your effect is negative ground btw.
My DIY site:
www.pdfelectronics.com
Zedmin_fx
The guy has a switch like this not sure where he bought it.http://www.pedalpartsplus.com/mm5/merchant.mvc?Screen=PROD&Store_Code=PPP&Product_Code=9001&Category_Code=SWI
I thought it was neg groud just cannt remember things like that so easly beeing sick and geting a headach while recording  doesnt help.
Zedmin_fx
hmm i am going to go back and tinker whith this, to see about the lfo bleeding thing
yeeshkul
#4
It has True Bypass and the signal is bleeding through the effect when the switch is off? Have you tried other switch? These cheapo DPDT are all Chinese, some of them are durable and some are complete bollocks. Measure the switch first. If it is ok, then it must be incorrect wiring. Was the trouble there before you rewired the circuit? After all, send a picture of the situation.
Zedmin_fx
yes, the guy said that the pedal had a really anoyying loud hum either on or off, and that he could hear the phasing while it was offalong with the hum.
I dont have the loud hum anymore, I am guessing that to be the backward cap. I could try another switch, the one I built a year ago does the same bleeding thing. I used Carling 316-B-PP  stomper from sb. I will go take some pictures
Zedmin_fx
ok, I am back with some pics, The jacks are only temporary as he has to drill the enclosure for them.
yeeshkul
#7
Hi, thanks for posting the pictures  :). What is the thing that bypasses the stomp-switch? And one more question - is the DC socket plastic(isolated from the case, well now it is :))?
Try to remove all the parts from the case and check it out again.
Zedmin_fx
on the stomp switch? Its a 0 ohm resistor  basically jumper I think they look cooler., Yea the jack is all plastic, I thought i had  a pic with it in there sorry. Check what after I remove it from the case? Do you mean see if it still bleeds?
yeeshkul
Yes. It is getting really strange, but is must be something you have just overlooked. Remove everything from the case and check out if there is any change. If you have any other SPDT at home, even toggle, slide or whatever then try another one.
Zedmin_fx
ok will do, I have a 3p2t and one of the lugs came off, I used to use it as a switch for a crybaby but sold the baby.
yeeshkul
Good, i am courious. One thing is when the vibe is not working correctly, troubles with bypass are almost always easy to repair as far as i can say.
Zedmin_fx
#12
O stupid me, I have it all wrong, The neo doesnt do the humming when the pedal is truned off. Only when you hve it on and arent playing your guitar will you hear the phasing. Gosh sorry for the stupid mistake man do I feel like a dumbass :icon_redface:
yeeshkul
So the bypassed signal is clean? Just when the Neo is on you can hear the phasing? That's the way it should be :) - as we know it from Hendrix bootlegs.
No troubles, it happened to me a few times :):)
Zedmin_fx
yea just when we are turned on and not playing I get the phase sound, when I play it seems to go away. Hot dam I am an idiot
        THANK YOU ALL SO VERY MUCH
Zedmin_fx
O yea Now all I have to do is add a on off led. I can do this with out having to change the switch right?
kurtlives
If your using millenium bypass, yes.
My DIY site:
Zedmin_fx
would it be easier to add a different switch or the millenium bypass which I have no I dea what that is?
Ripthorn
A new switch is easier, but a millenium bypass is cheaper than getting a new switch.  It is a method of using a dpdt switch for led indicator and true bypass invented by RG.  Check out Geofex for the article on how to do it.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
yeeshkul
You can add a LED that flashes with LFO and use the third row on 3PDT to "turn" the intensity pot down while Neo is off. That works fine and saves the bulb.
