pull-down resistor question
Started by rpjones, February 26, 2009, 08:06:10 AM
rpjones
Is there any benefit to using a pull-down resistor on the input of a circuit if using the grounded input switching method of wiring the 3pdt switch?
  If the cap spends time 'floating'...it can accumulate a charge, if it is tied to ground of course no charge can form.
Andi
I'd think it worth doing anyway - resistors are cheap.
yeeshkul
For example Screddy doesn't use pull-down at the input because he uses the mentioned 3PDT wiring - as he said.
bumblebee
Make sure you have the PD resistor on the effect side of the switch not the bypass side.
