Phasers?
Started by Arn C., March 01, 2009, 09:45:00 AM
Arn C.
I have a small stone phaser and I did a bunch of mods to it.  I was wondering if there is a way(this is a bit hard to explain) to maybe mix clean into the signal path.  I would like be able to turn down the phase sound a bit so it isn't as bold or pronounced.  going from a clean sound and when I kick this pedal in, I would like it to be a bit less pronounced.  I am not talking about the speed.  Is there a way to do this?
If so I could use some help in accomplishing this.
Edit:  I guess what I am trying to say is that I like the phasing and the volume level is fine, but I would like to bea ble to put the phasing sound more in the background so it is not so in-your-face, if this makes any sense.....
I hope someone understands what I am trying to say.
Arn C.
Auke Haarsma
there are depth mods for the P90. But if that is not what oyu are looking for, you could split the signal and use a blend pot to mix dry and wet.
Arn C.
Thanks Cynical man, just what the doctor ordered!!!!!!!!!!!!!!!
Peace!
Arn C.
