+9v +9v(t) Whats the difference ?
Started by _Boomsheeka_, March 01, 2009, 12:59:03 PM
_Boomsheeka_
Hello !
I have not been able to figure out the difference between these 2 symbols.
Thanks for the help
d95err
Are you by any chance referring to symbols in Gausmarkov's EAGLE PCB library?
If so, then +9V and +9V(t) are the same, except that the "t" version has a PCB pad associated to it. I.e. you use the "t" symbol once in your circuit, and then the regular symbol for all other references to 9V. This results in one pad on the PCB where you can connect 9V. Do the same for ground.
_Boomsheeka_
Thats it exactly
Thanks for the quick reply :)
