Ross compressor (tonepad) static sound problem
Started by bent, March 02, 2009, 02:11:53 PM
bent
Hi,
my ross build from tonepad http://tonepad.com/getFile.asp?id=9 is doing a strange sound.... in the background there's some sort of static doing morse code..... ???
mod made: variable recovery at fuzzcentral
power supply regulated and filter
the "static sound" is going away when sustain pot is at minimum or guitar volume is down.  :icon_confused:
i try to solved the problem by putting a cap from pin6 of ca3080 to ground, and bigger the cap was (start from 0.001 up to 2.2uf ) ,the static went away but the guitar sound too....  :-\ can't find a middle spot...
anyone have a clue to where else to look...  :icon_eek:  ?
thank's
bent
Long live the music.....
MikeH
My guess is you've got something going on in the 'pre-compression' part of your circuit and that noise is getting amplified.  I'd post voltages- do the whole "DEBUGGING: what to do when..." thing.
bent
voltage:
ca3080:
1- 0
2- 4.41
3- 4.39
4- 0
5- 0.67
6- 2.23
7- 8.87
8- 0
Q1:
0.76
1.25
8.08
Q2:
1.7
2.22
7.22
Q3:
0
0
7.75
Q4:
0
0.02
7.73
Q5:
7.27
7.73
8.87
THANK'S
BENT
MikeH
For your Q voltages could you label which voltage corresponds to which pin? ie CBE?
bent
MikeH
Somethings fishy with Q3 and Q4; check orientation or for solder bridges/bad joints/etc in that neighborhood.
ayayay!
The people who work for a living are now outnumbered by those who vote for a living.
bent
Problem found.....
i just found out that the problem wasn't the compressor, it's come from the guitar, cause i have the same static sound when i put my distortion whitout the compressor...
i change the volume pot few weeks ago, and i put a alpha pot 16mm, i think the pot might not be good...i'll try to find a real volume pot and change it to see if this is the problem...
thank's every one....
bent
JDoyle
Before you think it is 'solved'...
- Some of your voltages are kind of screwy - your V+ is all over the map on different parts: 8.87 on the chip and Iabc drive transistor (Q5), 7.7 on the rectifying transistors (Q3 and Q4), 7.2V on the phase splitter/output transistor, and 8V on your input transistor.
- The input transistor is really weird - the base should be biased to 2.8-2.9V (27k/56k+27k * V+ = Vbias, 0.325*8.87=2.88V) but yours is at 1.25V. Yet the base-emitter diode is just barely forward biased at 0.5V.
- elsewhere it looks like your bias voltage is 2.22 - a full diode drop smaller than the 2.8 that it should be.
If it works, it works. However, there do appear to be some issues with your circuit.
Regards,
Jay Doyle
