Looking for a switch - push to break toggle
Started by scaesic, March 02, 2009, 03:17:51 PM
scaesic
Why can't i find this switch anywhere?
I'm looking for a toggle style switch, which is
ON/MOM-OFF - i.e sits in ON position and you can toggle it off.
im looking to use this as a kill switch for my guitar.
it seems to be imposible to find...
Heemis
Just to clarify, are you looking for a toggle style switch or a push button?  I'm just trying to visualize how a momentary toggle switch would work... Are you saying you want it to be a toggle switch that bounces back to ON when you let it go?
And dude... let's try not to bring mom into this, parents just don't understand.
The Tone God
You are looking for a "normally closed" momentary switch.
If you are looking for a footswitch type version a quick look up at Digikey brings:
432-1207-ND
679-1044-ND
The second one while expensive has a nice soft feel.
Andrew
  Leave the guitar wiring intact, this is a nice default status, the pickup remains hardwired.
  Use common switch [as seen on TV, monitor, VCR salvage boards].
  Wire it across the Jack lugs.
  The switch only connects the signal to ground when held down.
