'herzog' type question-
Started by bobster, March 02, 2009, 05:57:26 PM
bobster
hi guys,
i have a little single ended valve amp 1xEL84 , 2x 12ax7 and one ez80. it has output tranny mounted on an elliptical 6 inch speaker.
i have read about the garner herzog thing which appears to be a small amp with load resistor and /or padded down with capability of plugging into input of larger amp say my 50watt marshall for a juicy distortion sound.
do any of you have the time and patience to tell me how to do this. im ok with solder iron and could wire up a simple circuit / jackplug out if i knew where to hook the wires etc ! the amp has its back panel off just now for ventilation and i can get at all of the circuit board o/p tranny with no access probs.
any advice appreciated!
bob
This is a link from aX84 showing the  Firezog which was the Herzog idea applied to Doug Hammonds Firefly amp.
http://www.charlestongolf.com/lineout/
dave
DougH
The firezog is designed specifically for the firefly output stage. You'll have to figure out what you need to do for your amp.
