Need help De-bugging MXR DIST' +
Started by LEON.01, March 03, 2009, 10:29:04 AM
LEON.01
Just finished it and it doesn't work!
This is the layout i used;
I followed everything on the layout except the wiring, i am using a DPDT but it works when bypassed so the wiring isn't the problem.
Was told on another thread that there is an error in this layout and to check it against a schematic, Done that! and now my head hurts!!!  ??? Would help if i knew what i was doing! lol! Told it was an error around the 10pf cap and 1m resistor area, under the IC.
Any way, Heres a couple of Schem's and layouts i found, I cant fathom it out for the life of me!
Parts on left being used;
http://www.tonepad.com/getFile.asp?id=115
http://www.generalguitargadgets.com/pdf/ggg_dist_plus_sc.pdf
http://www.generalguitargadgets.com/pdf/ggg_dist_plus_lo.pdf
I tried! the only things i can really say stood out were, the 1m resistor at the top left of the layout used, isn't that a pulldown resistor? and shouldn't it be connected to ground? i.e going across only 3 strips not 4, to the jumper to ground.
The tantalum cap! not on any schem's or other layouts!
The diodes and the .001 cap, i feel thr should be a cut track up thr somewhere?! no?
And finally the section thats missing, as on the GGG layout!
If its not any of them then i didnt spot it, the part that was mentioned earlier(under the IC) looks ok to me, but then i am a noob!  ;D
If anyone needs voltage readings of the IC, let me know and i'll take them. Try anyway!  :-\
Cheers fellas!
Leon.
arma61
Hi
another noob here  ;D , specially with  stripboards, but if you look at pin 6 it's connected to (GGG schem)
a Tantalum cap (c6)
a 10p cap (C5)
a 1M res (R8)
It is also connected to the electro cap on its left (C1 in the power section) , so it looks like there should be a trace cut at left of the 1m res.(R8)  (btw due to our net setup in the office I can't see the picture very well, low res, so I may be wrong :icon_mrgreen: ).
Cheers
Armando
"it's a matter of objectives. If you don't know where you want to go, any direction is about as good as any other." R.G. Keen
LEON.01
Thanks Armando, I think i see it now, right where i was first told! (if i'm right!)  ;D
So, like this?;
arma61
yes, that's it.
I've checked also the diode/cap you mention, it looks ok, on top C7 is connected to d1+, then  connected to d2- connected to 10K then to pot, on the bottom they all (C7 D1 D2, pot) go to ground through the first jump (starting from the left)
cheers m8
Armando
LEON.01
Yep, done!
Another one to add to the list!!!  ;D Liking the flashing LED thingy too!!!  ;D
Cheers Armando.  ;)
arma61
