Expression pedal question
Started by ronnie, March 06, 2009, 07:57:34 PM
ronnie
Hello,
I built john hollis ultra flanger, great pedal, I was wanting to know if it would be possible to control the regeneration pot with an external expression pedal,
I've read RG keens page about this, but, I'm haveing a hard time with it, if this is possible, does anyone know how I could wire the regen pot to a jack.
Thanks in advance,
I'd greatly appreciate any info I can get.
Ronnie.
ianmgull
I'm not familiar with the circuit you mentioned but in general it's not that complicated.
Use a stereo jack (three conductors) and wire each of the three wires going to the pot to the stereo jack. plug a stereo cable (trs) into this jack and to your expression pedal. put another stereo jack on your expression pedal and connect it to the lugs on the pot of your expression pedal.
Just be mindful to connect the correct wires to the correct lugs on the pot.
ronnie
Thanks Ian,
I'll give it a try and see what happens.
ronnie
OK, I tried hooking it all up as described, Everything works perfectly,
now the only problem is that when I install this new jack in the pedal, (I drilled a new hole in the pedal for it) it grounds out the connection to the expression.
Any ideas why this might be happening.
I really appreciate te help.
ronnie
Does anyone know why this jack might be grounding out the expression pedal,
I just can't figure it out,
it's driveing crazy.
ianmgull
Sorry, I didn't think of that.
Whatever you have connected to the sleeve will make contact with the enclosure and ground. Can you post the Schem? If one of the three connections is ground, make that the sleeve. Otherwise you could use a plastic washer (or plastic jack for that matter) to make sure that your sleeve connection isn't grounding.
sevenisthenumber
Quote from: ianmgull on March 07, 2009, 11:21:15 PM
That's it.
ronnie
Quote from: sevenisthenumber on March 08, 2009, 01:00:55 AM
Thankyou so much Ian, you've really helped me with this, I don't really know how to post images,
I'll just use a plastic jack.
Thanks man.
That's it.
