ROSS Flanger Repair
Started by jakehop, March 18, 2009, 07:36:16 PM
jakehop
Hi all,
I recently aquired two Red Ross Flangers. I've fixed one of them up now, so I get a sound through. However, when I compare it to the clips on home-wrecker.com, mine is a lot more subtle. If I turn adjust the trimports controlling the distortion and mix, I can get a good amount of wet signal, but at the expense of a white-noiseish "swish" on each end of the LFO-run, as well as all the time if I turn the manual/auto and manual all the way down.
The effect is, I think, similar to the MXR Flanger: http://i82.photobucket.com/albums/j279/bainzy007/flangerm117_12.jpg?t=1237419310
I hope someone has a couple of suggestions. I've been tweaking the trimpots for ages now!
Kind regards, Jake
