umble mod help!
Started by trauko, March 20, 2009, 03:09:25 PM
trauko
http://www.runoffgroove.com/umble.html
hi guys just wonder if anybody can help me out with a mod for this pedal ..i did not like at all the  tonestack ,no enought bass,mids are not really usedfull and way too much treble..
thank for the support.
Caferacernoc
Easy thing to try: Remove the 47p cap over the volume(gain) control. Then remove the 330p cap over the 220k resistor. Those are acting like treble boosters.
trauko
thank a lot anything to get more bass and something to get rid of the hiss
thank for the support!
trauko
i did removed the caps the pedal sound a lot better almost there, just need a little more bass in order to get even with the clean channel of my amp .. any suggestion ? also how can make the overdrive more clean less fuzzy ?
thank a lo for the support
Caferacernoc
Quote from: trauko on March 21, 2009, 10:28:13 PM
More bass but less fuzzy or muddy will be tough. At some point you will have to compromise. Because the only way to have really tight, but loud, bass is to first cut the bass, then distort, then boost the bass back up. Which takes a complicated circuit. The umble has the tone section too early in the circuit. If you boost the bass to much at the start it will sound more like a fuzztone.
