ROG Tonemender
Started by jonathansuhr, March 30, 2009, 02:47:23 AM
jonathansuhr
Definitely sounds like an interesting circuit, but I am a bit hesitant to build it.
I listened to the soundclips on the ROG page, and with the Tonemender engaged, there is bass cut in every example. is there only bass cut with this pedal? or is the bass boostable?
http://www.runoffgroove.com/tonemender.html
B Tremblay
Yes, you can turn up the Bass control and have a bass boost.  Unfortunately, the clips don't accurately convey the flexibility of the circuit.
B Tremblay
runoffgroove.com
captntasty
I highly recommend this build if you need an EQ - very versatile - you will find the sound you're looking for.
It is no measure of health to be well adjusted to a profoundly sick society. - Jiddu Krishnamurti
Ripthorn
You can't go wrong with this thing, that's about all there is to it.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
Hanglow
I like it a lot as well, lots of flexibility and boost available
jonathansuhr
Ok, I decided I'm going to build it but.. need some part replacement verifications.
Can I use 2.2M resistor at the input instead of 10M? And TLC2262 shouldn't be too much noisier than the TLC2272, correct?
punkin
This looks like a candidate for my bsiab2 box!
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
jonathansuhr
B Tremblay
Yes, TLC2262 and 2M2 will be fine substitutes.
B Tremblay
runoffgroove.com
FlyingZ
Quote from: punkin on March 30, 2009, 09:24:11 PM
Was going to junk mine as well until I found out it sounds killer on a cheap SS amp.
jonathansuhr
thanks guys, i just ordered parts and will post pics and soundclips once i finish.
punkin
#11
Hope I'm not hijacking this thread but was wondering...would you use this in place of a tone stack or in addition to? I'm wanting to use this in my BSIABII.
Ripthorn
This can be used in place of the tone stack if you want, or you can use it in addition to, it is all up to you.  I would probably use it in place of a stock tone stack, however.
MikeH
In a BSIAB you can remove the 'high-low-pass-bmpish' tonestack and replace it with the passive portion of the tonemender.  The question is: will you have enough output left over?  I think yes, but you may have to add another gain stage.
punkin
Hmmm....I was hoping to use the whole circuit as is. was planning to simply place the entire circuit immediately after the dc blocking capacitor at the last transistor stage in the bsiab2.
Uma Floresta
It's a cool EQ for sure
MikeH
Quote from: punkin on April 03, 2009, 04:54:27 PM
You could totally do that.  But if you're going to take the entir circuit as is, you could make the switching indepentent and use it as a boost too if you wanted.  Or make it a separate pedal and put both in an fx loop.  Regardless, yeah- you can do that.
mantella
I'm resurrecting this old thread because I recently built the tonemender - which I love - but also notice that it doesn't do much in the bass department. In fact, I barely notice the bass knob doing anything at all. Is this typical, or have I screwed something up?
punkin
Yeah mine was a little weak there too but all in all very happy with it.
compuwade
My bass control works quite well. So maybe there is something wrong with your circuit.
