DC power supply filter
Started by 9re9, April 02, 2009, 04:28:07 AM
9re9
Hi ,
I have a 24VDC unregulated power adapeter and I am trying to build a power supply filter which can filter out the 60Hz hum. Any schematics to share? The output voltage must be 24VDC.
Greg
km-r
Look at it this way- everyone rags on air guitar here because everyone can play guitar.  If we were on a lawn mower forum, air guitar would be okay and they would ridicule air mowing.
Auke Haarsma
MarcoMike
if you have 24V dc unregulated the 7824 would not work... it deserves a couple of volts more than the regulated output to work... maybe you can try with a LC filter (inductor-capacitor). the higher the frequency, the better its effect... so it will probably remove spikes from your DC, asnd reduce the 60Hz hum a bit. but the voltage loss is almost zero so you will keep the 24V output.
have some fun with duncan's amp's "Power Supply Designer"
Only those who attempt the absurd will achieve the impossible.
