Charge Pump Issue
Started by bootsytakes6, April 02, 2009, 10:19:52 PM
bootsytakes6
Hello all, first time poster, long time effects DIYer. I've just recently got into doing circuit layouts in Eagle CAD and had a quick question about a charge pump/ voltage reg I've been working on for a Forumvibe project. I made this board from the Charge Pump schematic here: http://www.geofex.com/circuits/+9_to_33.htm and the Voltage Regulator in the Forum Vibe instructions here: http://www.lynx.bc.ca/~jc/ForumVibe.pdf
This is my first time building a board from the ground up, and I'm having some issues with it. I'm not getting the +17V out of the charge pump section when I test it with a 9.24V power source (PP2). Not sure what the problem is, maybe a trace out of place from the schematic, or C1 is oriented wrong, or the IC I chose (TC1044S) isn't a good replacement for the MAX1044. The TC1044 has the same pinout so I thought it may work, and I"ve been staring at the schematic hoping to find a silly mistake but haven't come across it yet. Anyways, here is the layout from Eagle:
Charge Pump Section:
IC1: TC1044S
C1/ C2: 10uF Polarized Electrolytic
D1/ D2: Schottky 1N5817 Diodes
ForumVibe Voltage Regulator Section:
IC2: LM78L15
C5: .33uF 50V Film Cap
C6: .01uF 50V Film Cap
I laid it out so that the +17V from the charge pump feeds right into C5 and the regulator, then exits to the main board via the two pads above C6.
The pads are as follows from left to right:
Ground / +9V IN / +Voltage out to FV board / -Voltage (?) out to FV board
I'm getting 4.78V at pin 2 of IC1, and that gets bumped up to 9.2V after C1. By the time it gets through the diodes I'm down to 8.82V feeding the regulator section :/ Any assistance out there from the gurus?
.Mike
I'm closer to a n00b than a guru, but...
I think you are right that C1 is backwards. On the datasheet for the 1044S, Figure 8 (Positive Voltage Multiplier), the negative side of C1 is facing pin 2. On yours, I believe that it is backwards.
Is that the fix? I have no clue... heh.
Mike
If you're not doing it for yourself, it's not DIY. ;)
My effects site: Just one more build... | My website: America's Debate.
WLS
Quote from: .Mike on April 02, 2009, 11:29:25 PM
Mike
Mike, you're right c1 is backwards.
As far as th TC-1044 in place of the Max-1044. I 'll think you'll find it as an excellent choice. :)
Bill
Since I've breadboarded it I can only blame myself.
But It's Just A Chip!
bootsytakes6
Thanks for the replies. I flipped C1 around and still getting the same voltages. hmmm. I'm stumped then unless my layout is incorrect. I've already completed a Neovibe for a buddy of mine which I used a toroidal transformer for the power. I wanted to try something a little different with this FV to keep it more compact and stray away from the wallwart. Sigh....
ahermida
Take IC2 out and measure the voltage at C2.  What does it read?
Alf
Andi
Shouldn't pin 5 be grounded? That's how the 7660 works.
Ripthorn
Is your regulator oriented correctly?  I tried checking a data sheet but it was thoroughly unhelpful.
Exact science is not an exact science - Nikola Tesla in The Prestige
https://scientificguitarist.wixsite.com/home
solderman
#7
Quote from: bootsytakes6 on April 02, 2009, 10:19:52 PM
IC1: TC1044S
IC2: LM78L15
Check the layout at the bottom of the PDF. If you follow the layout its gonna Work I have built and verified it.
http://solderman.fatabur.se/TT/TT.pdf
Red=+ V
Yellow=+ 2x V
Green = GND
//Solderman
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
solderman
#8
Quote from: solderman on April 03, 2009, 01:44:57 PM
IC1: TC1044S
IC2: LM78L15
Red=+ V
Yellow=+ 2x V
Green = GND
Square pad is + on Caps and diodes etc Round dot on IC is pin 1
//Solderman
[/quote]
www.soldersound.com
.Mike
Quote from: Andi on April 03, 2009, 10:10:15 AM
That's what I was thinking too, but the layout posted by solderman doesn't have it grounded either.
bootsytakes6: I'm wondering, did you just pull C1, flip it around, and fire it up? Or did you replace C1 with a new capacitor? It would seem to me that putting an electrolytic in backwards and then pumping it would destroy the capacitor. My research indicates that it could happen very fast, and could possibly make it a short circuit.
I'm particularly interested in this because I plan on building a few 1044S supplies for submini projects at some point down the road, so I would love to see the solution to this.
Mike
Using a charge pump as a -ve voltage supply, pin 5 is the -ve output and has a cap to ground. But as a voltage multiplier pin 5 in not connected.
http://www.diystompboxes.com/smfforum/index.php?topic=74729.0
bootsytakes6
Thanks a mil for all the replies, you folks are great. It was actually something extremely simple and stupid...I got sidetracked last night after I desoldered C1. I turned it around but forgot to solder it back in place, sooooo when I got back to it and tested my voltages the cap was just loose in the hole :icon_redface: Can't believe I didn't notice that..Doh! It's always something silly.
The board works great now, I'm getting 13.49V at the + side of C1, 17.89V feeding the regulator section, and a regulated 15.04V to feed the ForumVibe! Maybe I can get it up and running today  ;D
Here's a shot of the completed board for your enjoyment:
Andi
Quote from: frequencycentral on April 03, 2009, 02:39:54 PM
Must just be the 7660S that needs that then. Don't mind me. :)
orangetones
Have you read this thread?  IT appears that using a chargepump is not wise with the Neovibe/ForumVibe.
Is the TC1044S any different than the Max1044?
http://www.diystompboxes.com/smfforum/index.php?topic=42888.0
Quote from: Andi on April 03, 2009, 05:48:54 PM
Actually, .Mike pointed out to me by PM that the datasheet shows pins 5 and 6 grounded for voltage doubling. I'm going off R.G.'s schematic, which shows no connection to these pins. I've built quite a few charge pumps now, using multiple doubling stages putting out ~80 volts, I've never grounded those pins. Interesting though, I'm curious about this issue, I'll do a bit of investigation.
.Mike
Quote from: frequencycentral on April 03, 2009, 06:22:43 PM
Looking at the datasheets for the MAX and the TC, pin 6 is labeled as "LV." The TC1044S datasheet says it stands for Low Voltage. It apparently should be connected to ground when V+ is < 3.5V:
Quote from: TC1044S DatasheetTo improve low-voltage operation, the "LV" pin should be connected to GND, disabling the regulator. For supply voltages greater than 3.5V, the LV terminal must be left open to ensure latch-up-proof operation and prevent device damage.
I would assume it is the same for the MAX IC.
Mike
Quote from: .Mike on April 03, 2009, 06:40:38 PM
Thanks Mike, great info.  8)
So thats pin 6, but what about pin 5?  :icon_eek:
bootsytakes6
Quote from: orangetones on April 03, 2009, 05:50:17 PM
I've read it now....never considered that. I didn't notice any differences on the datasheets, but I was mainly looking at the pinouts for the IC to see if they matched up.
So, basically the pump doesn't put out enough current to run the 12V-60mA incandescent bulb in the center of my board? I have a 12V-40mA bulb lying around, but that's too much current too it seems from reading that post.
Quote from: bootsytakes6 on April 03, 2009, 07:04:16 PM
The LT1054 does the same job as the TC or the MAX, and have the same pinout (I believe), but it puts out 100ma, that should do the job for you. A bit more expensive though.
orangetones
Quote from: frequencycentral on April 03, 2009, 07:06:46 PM
Smallbear has the lt1054 for $1.70 and the MAX1044 for $3.50.  So that one is cheaper there!
