Tube factor mods? (attached schem link)
Started by Xavier, April 07, 2009, 05:04:58 AM
Xavier
http://www.free-service-manuals.com/Audio___Hi_Fi/Hughes___Kettner/Hughes_&_Kettner_Tube_Factor_Schematic_Diagrams_L66999/
I would like to mod my H&K Tube Factor for more gain . This tube OD has 2 modes, mode 1 sounds pretty goos with plenty of attack but i would like it to have more gain. Mode 2 has more gain but sounds way too dark and compressed for my tastes.
I could obviously mimic the Okko mods by adding a boost circuit , nevertheless maybe changing a couple of resistors / caps would do the trick.
Any suggestion?
anchovie
The gain mode switch is what's labelled on the schematic as 'slc3', and is part of the circuitry surrounding IC1A. In high-gain mode, it switches a 220 ohm resistor (R8) in parallel with a 6.8k resistor (R6) that changes the gain of the op-amp stage from x2.2 to about x70. To increase the gain of mode 1, lower the value of R6. Might be worth replacing it with a 5k pot wired as variable resistance so you can experiment, then when you find the level that you like you can measure the pot and replace with a fixed value. There'll be a point somewhere in the sweep of the 5k pot where mode 1 starts to sound like mode 2 and you can then back off from there to find where the signal stays bright.
Xavier
Wow anchovie, thanks for the reply  :icon_eek:  !!!
I will try as suggested, again thank you for taking the time !!!
kupervaser
Has anyone tried this already?
A friend of mine has this pedal and asked me to add a second volume control to make it possible to adjust both channels separatly. What should be done?
THanx
gtudoran
Or you could use paralel capacitors with R30 and R31: a value of 10uF for a aprox. full range response could be a solution.this will increse the gain a little bit and have a little more tube tone in your sound (more tube drive then op-amp drive).
This is just my ideea.
Best regards,
Gabriel Tudoran
Analog Sound
gtudoran
SOrry for double post: or you could change the anode rezistors (form first, second ore both triodes for a maximum of 220k). Or you could sacale down the rezistive divider formed out from R19/R20 witch goes in to the first triode grid.
Regards
diversionist
Is there an easy way to extend its bass range, so you can use it with bass guitar?
Cheers,
div
