Help me fix this old Maxon treble booster
Started by manson, April 07, 2009, 09:38:08 AM
manson
This is the Maxon MB-30 treble booster, but it doesn't work. Several wires are loose or missing. The orange wire was connected to the lower middle lug of the switch. And the battery connector is missing completely, and I don't know where it should go. Heck I don't even know what the input or ouput is :)
Can you help me fix this little thing? I'd like to hear what it sounds like :)
Look here for more pictures:
http://s113.photobucket.com/albums/n236/hoppekee/Maxon/
foxfire
it looks like it is just a LPB/screaming bird. looking at this picture, the orange wire soldered to the middle lug of the switch is your output tip and the lug to the left of it is your input tip. the bottom right lug is you 9vdc and ground is the black wire.
~arph
Input, I guess the little hole next to the lower left cap..
Output, Little hole to next to the top right cap.
Gnd is the black wire.
Pwr seems to be connected to the lonely switch pad below the letter ax.
manson
Ah yes it looks a lot like this one:
Only the 430k / 43k are 470k / 47k here. The white dial must be the volume pot, it's a 50k-B. Oh and the transistor is a 2SC828. I'll try to wire it up, thanks!
~arph
I might have switched the input & output.
foxfire
Quote from: ~arph on April 07, 2009, 11:27:25 AM
the output is actually the middle lug of the pot which has a trace running to the switch...
manson
It's working! And it boosts treble allright.. it's a pretty useless effect haha. I might change the in/out caps to see if it'll sound more like a lpb-1 :)
theehman
Quote from: manson on April 07, 2009, 02:04:18 PM
For an LPB-1, change the caps to .1uf.  Put some bigger caps in for a Mole.
Ron Neely II
Electro-Harmonix info: http://electroharmonix.vintageusaguitars.com
Home of RonSound effects: http://www.ronsound.com
fx schematics and repairs
foxfire
Quote from: theehman on April 07, 2009, 02:07:31 PM
and then put another LPB or 2 behind it...
~arph
Why not keep it original and build two lpb's?  ???
