what type of pot?
Started by ppatchmods, April 08, 2009, 03:21:12 PM
ppatchmods
what type of pot would I use to blend 2 things? similar to the pot on an amp that has capabilities of blending 2 different types of tubes. thanks
When your life is over, will any of this STUFF really matter?
svstee
Some kind of dual ganged pot, Like you see on a sparkledrive.
ppatchmods
if i wanted to blend 2 components, how would i wire a dual-gang? it has 6 lugs and i have one ground and 2 positives. can it be done?
armstrom
#3
A pure "blend pot" setup is really quite simple. Just use a linear taper pot and wire one signal source to lug 1, the other signal source to lug 3 and the output (blended signal) to lug 2. Perhaps the most common use of this arrangement is in the Big Muff tone control. It simply consists of a high pass filter and a low pass filter that are blended together through a linear pot.  The size of pot you use will be determined by the input impedance of the next stage. The two "halves" of the pot (from lug 1 to 2 and from lug 3 to 2) form voltage dividers with the input impedance of the next stage. Common values are 50K and 100K.
ppatchmods
awesome. that is what i thought in the beginning but i got confused with logistics. thanks
