Crybaby mod
Started by rbcguitar, April 08, 2009, 06:15:37 PM
rbcguitar
I did this mod to my crybaby;
http://www.diyguitarist.com/DIYStompboxes/WahMod.htm
Sounds real good, very vocal like, I noticed a few things though.
I seem to hear a lil modulation going on when really moving wah fast and when I am playing with high-ish gain i seem to hear a lil bump when rocking wah back and forth.  Anyone know what might be going on?
Also, I might have made a slight mistake, on bottom left of picture, I replaced the stock 470 ohm resistor at the emitter of Q1 with a 270 ohm resistor, the trace between Q1 emitter and the top of resistor seemed to be solder only so i clumped solder between the two, could this be the source of the modulation? (in a weird way it actually sounds kinda cool)
Any insights would be awesome,
Thanks in advanced
Paul Marossy
Quote from: rbcguitar on April 08, 2009, 06:15:37 PM
Thanks in advanced
Hmm... mine doesn't do that. I'm not sure why yours would be behaving like that. I might have to do with that clump of solder.
newfish
Hmm,  carried out the same mod, also without the 'bump' you described above.
..maybe you started something new...
:icon_wink:
Maybe clean up the solder 'blob'  and see what difference that makes.
Also - did you carry out all the mods described on that page?  I found the 'sweep cap' mod made my CB sound very un-wah-like.
Happiness is a warm etchant bath.
Paul Marossy
#3
QuoteI found the 'sweep cap' mod made my CB sound very un-wah-like.
You could also try a .015uF cap instead. Some people have reported good results using that value.
One thing I have found with these CryBaby mods is that the end result is not always consistent. I did the "Fat Wah" mod to one of my GCB-95s and it worked great, but when I did to a friend's exact same wah pedal, and it was problematic and I had to revert back to the original circuit. I still haven't figured that one out yet. Maybe it's due to variations in the actual part values on any particular PCB? I dunno...  :icon_confused:
