Clean boost
Started by fuzzo, April 13, 2009, 01:23:56 PM
fuzzo
Hi,
I would like to do another clean boost, but I don't which one I can make. I've already done Zvex Sho , LPB1 (great) and AMZ booster (BS170). I would like to do a clean boost that add a little thing to my sound, a boost with a "personality" .
Any ideas ?
Maybe take the first stage of a nice tube amp and transform it into Jfet boost (like I saw in layouts gallery with a boost based on first Marshall stage) ?
Andi
Basic op-amp gain with a BM tone control or sommat?
fuzzo
I don't like the BM tone and its mid scoup.
Acutally I need one knob (boost or volume).
QuoteBasic op-amp gain with a BM tone control or sommat?
Why not, but the question is the same, how create something fine and not so neutral.
m-theory
QuoteI would like to do a clean boost that add a little thing to my sound, a boost with a "personality" .
You're not describing a clean boost, imo.  I would strongly recommend you try a peppermill.  Yeah, I know that it's a mild overdrive circuit, but it's also a terrific, slightly dirty boost.  Either that or a minibooster, although that can be pretty distorted, imo.  Depending on how you run your amps, that may or may not work for you.
m-theory
QuoteAcutally I need one knob (boost or volume).
Either just a minibooster or a Peppermill with no gain knob...just use a fixed resistor in place of that pot.
Try Mark Hammer's The Crank, that's clean if you want it to be or you can dial in a bit of grit.
MikeH
The stratoblaster, Brian May Treble Boost, and Dallas Rangemaster all certainly have what I'd call personality.
Also Yun's rocketboost.  That one's got personality too.
Andi
Quote from: fuzzo on April 13, 2009, 03:10:36 PM
You said you didn't want neutral... and the BM tone control is easily tweaked, especially with the Duncan Amps tool.
fuzzo
thanks for all your answers.
QuoteEither just a minibooster or a Peppermill with no gain knob...just use a fixed resistor in place of that pot.
Yeah the AMZ mini booster seems to be cool , I'll try to find some soundclip or youtube vids. I could add a trimpot inside to have a gain control.
The Perppermill is a tube pedal from tube town,  no ?
QuoteMark Hammer's The Crank
I don't know that one, I'm gonna look for informations.
QuoteYou said you didn't want neutral... and the BM tone control is easily tweaked, especially with the Duncan Amps tool
I did that on my  Big muff and DS1 tonestack in using Ducan amp tool . But I don't like this EQ control, I don't know why maybe too extrem for me, I prefer the Rat tone control or simple low pass filter.
QuoteThe stratoblaster, Brian May Treble Boost, and Dallas Rangemaster all certainly have what I'd call personality.
I've to finish a dallas range master with range pot (cf. D*A*M red booster) so I really want a  " clean boost" . I don't know the Stratoblaster.
Actually I need one knob 'cause I've already drilled my box for one control.
ayayay!
#9
To my surprise, the Trotsky Drive earned a place back on my board.  Placed last in the chain.  Using a 2n2222, gain all the way down, volume all the way up.  Asymmetrical clipping.  Great booster with just a wee bit of squishy dirt to keep it from being too clean.  Very responsive to picking dynamics.  :)   Plus, you could leave the diodes out altogether or add a lift switch for them.
The people who work for a living are now outnumbered by those who vote for a living.
Der Groovemeister
My favourite booster is the Fetzer Valve. It adds a bit of Tweed to your sound. Very nice imho. ;D
"What do you mean, dynamics? I'm already playing as loud as i can!"
Gus
svstee
BAARON
Quote from: fuzzo on April 13, 2009, 01:23:56 PM
I second what Groovemeister said.  If you want a jfet booster that mimics the first stage of a tube amp, a Fetzer Valve is a good starting point.  That said, unless you hit it with a pretty hefty signal you probably won't get much grit out of it, so it'll stay pretty clean if you're plugging your guitar straight into it.  Building it with a J201 might get you some unboosted clipping if you have hot pickups.
Here's a very in depth look at the Fetzer.  There are a few complete variations of it posted on the page, as well as lots of information about tweaking it.
http://runoffgroove.com/fetzervalve.html
B. Aaron Ennis
If somebody makes a mistake, help them understand what went wrong.  Show them how to do it right.  Be helpful.  Don't just say "you're wrong, moron."
The French connection
#14
Quote from: Gus on April 13, 2009, 07:04:53 PM
Have tried the beginner project or
http://www.diystompboxes.com/pedals/gusOverdrive.gif
Fuzzo, I've buiild all the booster you've done plus the Gus booster from the beginner project, and this last one is my favorite. It gives some grit to the sound and a nice tone too...And it's so easy to make. Try it you'll be very please!
Thanks Gus for this nice little booster!
Salut!
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
fuzzo
#15
thanks guys
Actually I realize there's any booster better than another one, everybody has different ears and different tastes. So the only solution to find a good one it's to do a booster and if I don't like it make another .
m-theory
Doesn't hurt a bit to make a few to try out.  You'll never know what you really prefer until you've auditioned some worthy candidates.  They cost nearly nothing, and take veyr little time to build, so it's not as if you're out a great deal to experiment with different flavors.
armstrom
#17
Since you said you don't like the mid scoop of the BMP tone control you could try something like this.
I've been toying around with this circuit in spice simulations. I got the tone stack from this site: http://members.tripod.com/roymal/ReverbTone.htm  (lest anyone think that it's my own design). The first gain stage is just something I've been working on to drive my DSP board. The tone control is kind of a "tilting" control that boosts bass or treble while cutting the other end (if you boost bass it will cut treble). At the middle position the frequency response curve of the active tone control is dead flat. I'll have to recreate the spice model if anyone wants to see the frequency response curves of the entire circuit.
You could increase the 10K pot used for the gain control in the first stage with a larger value to get more gain. You could also ditch the 100K volume pot on the output and just use the gain control for a volume but since the gain pot has DC on it it could be a little scratchy. The master volume control always seems like a good idea for a pedal since you never know what might be attached to the output!
Edit: Oops... that 1n cap after the first gain stage needs to be much larger. As close to 1u as possible... maybe 470n or something. Otherwise the lows are rolled off WAY too much.
superferrite
It ain't really clean, but the Sparkle Boost is classy and adds just a touch of hair.
Psychedelic Garage Metal
fuzzo
Cool schematic armstrom but not really what I'm looking for. It seems to be a cool thing, I put in my documents book.
QuoteIt ain't really clean, but the Sparkle Boost is classy and adds just a touch of hair.
I'll see what it is.
