Battery snap shorts on box. Positive ground build.
Started by Focalized, April 14, 2009, 02:23:17 AM
Focalized
When the battery snap touches the box it cuts the effects sound.
Using a combo of the PNP wiring from GeneralGuitarGadgets.com:
And this switch wiring:
Should I have followed the GGG layout fully? Or is this normal? Shouldn't be.
anchovie
Is this with the battery connected to the snap or running off a PSU and having the snap loose in the enclosure?
Andi
MohiZ
#3
It's because only the positive terminal of the battery is disconnected when using the DC jack. On a negative ground build, this prevents the snap from shorting, but on a positive ground build you'd need to have the negative terminal disconnected.
The way I see it, the only way around this would be to have DC jacks with the lugs swapped, but I don't think those exist. Or use a center positive DC plug, and wire the battery snap the other way around. You're probably best off just taping the snap as suggested.
megadan
Quote from: MohiZ on April 14, 2009, 08:34:50 AM
Agreed, I usually put a piece of tape over the battery jack when it's not in use, even in a neg ground circuit. You never know what will come loose in my shoddy builds ;) so better safe than sorry, it's just a little piece of tape :)
Andi
Even in normal ("negative ground") circuits it's worth taping off - it can still short things to ground!
Focalized
Thanks for the info.
Yeah it shorts when i'm using my Pedal Power 2 supply. Just wanted to make sure the wiring wasn't an issue.
I though I could get some really cheap battery snaps and cut off the snaps. Use them on the box if I don't have a battery in it.
Or just get the ones that snap on a battery to cover the posts.
Andi
Focalized
No reason. I just like parts I guess. If I sold it or others I'd like it to have something permanent to block it from shorting.
MohiZ
One thing I've found nice is a battery adapter for connecting a 9V battery to a DC jack on the outside of the box. It's basically just a snap with a piece of cable and I got it as a compliment from this German store I always order from. When you have one of those you don't have to have a battery snap inside the box, which is useful when using small enclosures that couldn't accommodate a battery inside them!
