ada flanger power supply?
Started by daverdave, April 23, 2009, 06:54:28 AM
daverdave
Hey all, I've just finished putting together the sad1028 version of the ada flanger, now I need a power supply. I've seen one that's 18v 830ma, would that be ok to use?
moosapotamus
18VDC 830mA should be fine.
~ Charlie
moosapotamus.net
daverdave
StephenGiles
Quote from: daverdave on April 23, 2009, 06:54:28 AM
Slip of the finger there on the number pad :icon_biggrin:
grathan
I just bought a 18vdc 150mA off ebay for this pedal with the ic10 mn3007. I wonder would that be big enough for the draw on this pedal?
oldschoolanalog
Quote from: grathan on April 23, 2009, 04:51:39 PM
More than enough.
Hey all, I've just finished putting together the sad1024 version of the ada flanger, now I need a power supply. I've seen one that's 18v 830ma, would that be ok to use?
For this and a decent sized pedalboard...
Nitefly182
IIRC the actual draw of the A/DA is only about 40ma. The Dunlop 18v 150ma worked perfectly with mine before I dropped in a charge pump.
oldschoolanalog
Quote from: Nitefly182 on April 24, 2009, 09:24:47 PM
No heterodyning issues?
Nitefly182
Quote from: oldschoolanalog on April 24, 2009, 09:53:27 PM
Thats ring modulation right? The charge pump hasn't created any issues as far as I can tell.
