Please help me with a dynacomp debugging
Started by gtudoran, April 24, 2009, 04:58:04 AM
gtudoran
Hello, and i'm rilly sorry to start my posts witha problem. Last night i've done a dynacomp clone ( tonepad layout http://www.tonepad.com/getFile.asp?id=9) no mods no nothing just the original schematic.
I've done 2 substitutions (because i didn't have the values(
- the 4M7 rezistor i've replace it with 2 x 2M2 rezistors in series
- the trimpot that is 2K i've used a 10k
Now the problem is this: NO sound only at the max of level pot and at that position the sound is verry dimed and with a lot of distorsion. I've put a TS808 clone in front of it and the sound is louder but also with lot of distorsion. I also have a lot of humm.
Now the question is that: could that 10k trim pot to have souch an influence? Could i replace it with 2 x 1K rezistors just to make somme tests.
I don't have the posibility right now to make some mesurements bc i'm at work.
I would appreciate very much any ideea that will come around.
Thx in advance,
Gabriel
PS: I couldn't wait till i get home to make somme mesurements... i'm sure you know the feeling of a fail.
Quote from: gtudoran on April 24, 2009, 04:58:04 AM
That's OK. That's how a big fraction of the people who get here get here.
QuoteLast night i've done a dynacomp clone ( tonepad layout http://www.tonepad.com/getFile.asp?id=9) no mods no nothing just the original schematic.
The first one is OK, the last one is a problem.
You have mulitple problems. If you haven't yet, read "Debugging: What to do when it doesn't work", which is always at the top of this forum.
QuoteNow the question is that: could that 10k trim pot to have souch an influence? Could i replace it with 2 x 1K rezistors just to make somme tests.
Some but not all. In fact, you can replace that trimpot with two 1K's forever. It's almost never needed.
MohiZ
Sounds a lot like a badly biased transistor. That's where I'd start looking, anyway. You could measure the voltages from the transistor pins and post them.
gtudoran
First i wanna thank you all for the help you provided.
Indeed was a bad biased tranzistor... but not because it was some component of wrong value...nooo mam... but because i was stupid and made a mistake in the pcb (when i draw it). Now everything is smooth a clear... ohh but that mistake cost me a pice of CA3080... is not much but it's smth.
Again a lot of thank to you all and especially to Owen James who helped me a lot.
PS: I didn't put a trim-pot anymore it works magniffic with 2 x 1K rezistors.
Best regards,
Gabriel Tudoran
owenjames
PCB mistake in the end then ;D its always somethign simple, i had a bihatch of a time trying to simulate that circuit. juat putting a sine wave into it and then varying the amplitude with a pot was the way to go. using the 10k pot did seem to make a difference but it was hard to tell what difreence.  I also tried replacing the CA3080 with the VCA i showed you, it wokrs well.
gtudoran
Indeed... pcb mistake...again owen lot of thanks for you time and help.  :icon_redface:
