Help with DOD280
Started by ppatchmods, April 30, 2009, 03:50:41 PM
ppatchmods
I used the tonepad layout and with or without the led parts I get a distorted low signal. Anyone had this problem? Does it matter what type of switching tranny you use or what single op amp? thanks
When your life is over, will any of this STUFF really matter?
aron
Tell us what you used and then we can tell you if it's ok. But the answer is yes it does matter.
ppatchmods
for the switching tranny I used 2n2222 and the ic I used a tl072. thanks
ppatchmods
bump for the help. thanks
ppatchmods
anyone have a similar problem? what about on the dynacomp? thanks
ppatchmods
no answers as of yet but a couple questions that might solve my problem.
Is it safe to assume that a j201 is a good replacement for a 2n5485. I think the answer is yes but just checking.
What is a good replacement for the lm358? I have lm741's, tl071, tl081, tl072
Thanks to anyone who responds...at all!
-John
MikeH
The J201 should work fine for the millenium.
You can Google the data sheets to see if any of the opamps are suitable replacements.
First step is to verify your pinouts.  Second step is posting voltages.
MikeH
And the dynacomp is a completely different animal all together...
ppatchmods
oldrocker
Yes I have built this and I believe that little bit of distortion is the nature of the beast.  I tried everthing and could never get rid of it. It's a shame really since besides the forementioned problem it is a cool compressor.  For a similar but better opti-comp try the John Hollis Flatline.  You'll need some 1n34a GE diodes for this though.
