Identifying IC chips that have been sanded down?
Started by jimosity, May 06, 2009, 08:00:42 AM
jimosity
I have a couple units that I want to RE and a couple IC chips have been sanded down to avoid this sort of thing.
What options are there for figuring this sort of thing out?
Jim Rodgers
jim@americanhc.com
theehman
Which units are they?  Someone may have already done the work.
Ron Neely II
Electro-Harmonix info: http://electroharmonix.vintageusaguitars.com
Home of RonSound effects: http://www.ronsound.com
fx schematics and repairs
earthtonesaudio
An educated guess is the fastest way to figure it out.  Part of that guesswork includes the assumption that if the part is sanded down or disguised like that, it's probably not anything out of the ordinary.  Next would be: identify power pins, determine the pinout based on the function of the circuit.  Possibly scope probe the chip in-situ with a function generator to see what's going on.  If it's a common pinout (dual op-amp perhaps) and you really want to figure out what it is, it gets exponentially more difficult.  You can remove the chip and test it's parameters (bandwidth, gain, CMRR, PSRR, input resistance, etc), but in my opinion that's too much work.
Quote from: theehman on May 06, 2009, 08:05:55 AM
Yep, or that.  :)
Seeing where the power lines go and identifying inputs and outputs is often a useful step, however it would not be able to tell you, for example which 8-pin dual op-amp is being used, only that it was an 8-pin dual op-amp.  On the other hand, often that is sufficient information to produce a reasonable replica.
jimosity
Both are Axess Electronics units.  One is a GRX-4 and the other is a BS-2.
Jim Rodgers
jim@americanhc.com
