Voltage drop resistors for LEDs?
Started by grolschie, May 10, 2009, 12:54:35 AM
grolschie
Hiya.
I have some 3mm blue LEDs (2V, 15-20mA) for a pedal that I am building. What resistor values should I be using? I see some schematics use values as high as 10k-15k for LEDs, but when using 10k I get no light.
I used an online calculator and its seems that the correct value is 470ohm - which is clearly much smaller. I realise that I could just try much smaller (or even the recommended value). The bezels are quite fiddly to get at in the pedal, so I don't want to mess around too much with various resistors in this particular case.
Generally speaking, what is a good rule of thumb for LED resistor selection in pedals? I want to avoid popping, conserve power, and it doesn't need to be overly bright. Thanks in advance.
Cardboard Tube Samurai
Formula: Vs - VLED/i = required resistor
9v-2v = 7v
7v/0.015 = 466.66666666666666666666666666667r
470r is what you're after!
grolschie
Best I go with the calulated value then. Many thanks.  :)
lerxst88
yeah calculated value + a little will give you the brightest LED but if youre not sure of voltage drop or current draw of the LED, try using a 1K resistor.
MohiZ
#4
I wonder if 15mA is a bit much compared to the consumption of the effect itself? It is pushing the limits of the LED. I used to use 470R resistors without any problems as well, but 1k or 2k2 resistors don't seem to make the LED any dimmer. I'd go with the biggest value that's still bright enough for you, so as to conserve power and lengthen the lifespan of the LED.
grolschie
 :icon_redface: :icon_redface: Errr...... I tried the 470ohm resistor, no joy also..... because I had forgotten to wire the 3PDTs to the ground. Something so simple and I didn't see it. :icon_redface:  :icon_redface:
Anyways, I soldered two wires in there and these blue LEDs are so bright! Any recommendations of a value that would tame them alot, but still work ok? Thanks and sorry about that.  :)
I think the last time I was having the same brightness troubles, I went through a whole range of resistor values and it wasn't until I got somewhere up around 4k7 that it was reducing the brightness to a bearable level. I really don't understand why people insist on "ultra-bright" LEDs in effects applications
grolschie
Thanks. I wanted blue, simply beause it wasn't green or red.  :)
tranceracer
Quote from: grolschie on May 10, 2009, 06:19:18 AM
If you have a 100K pot laying around you can try using that to "dial-in" the brightness of the LED then take the reading of the POT when you've found the right setting.  I've done this and it's saved me a lot of time swapping out resistors.
Andi
Quote from: Cardboard Tube Samurai on May 10, 2009, 06:32:38 AMI really don't understand why people insist on "ultra-bright" LEDs in effects applications
They can be handy for daytime outdoor stuff. Generally I'd agree though - I use ultrabrights but a fairly big resistor so you get plenty of brightness but not too high a consumption.
R O Tiree
Quote from: tranceracer on May 10, 2009, 02:54:05 PM
Better to use a 10k pot. The useful range of current limiting resistors for a 9V supply is in the 470R to 5k or so. Using a 100k pot puts you in the 0% to 5% band, as opposed to 0% - 50% band for a 10k pot. Much easier to dial it in?
...you fritter and waste the hours in an off-hand way...
tempus
QuoteI really don't understand why people insist on "ultra-bright" LEDs in effects applications
Well, if you can use a 4.7K resistor it'll draw a lot less current, which is nice in any case, but especially if you're powering them directly from uProcessors.
grolschie
Thanks everyone. I think I will try a 4.7k this evening.  :)
Quote from: tempus on May 10, 2009, 04:17:17 PM
I'd still prefer to not be blinded when switching my pedals
grolschie
Would it still light up with a 10-15k?
biggy boy
Quote from: Cardboard Tube Samurai on May 10, 2009, 04:59:01 PM
Hey maybe that's why guys like Slash wear sunglasses when they play :icon_smile:
80k
I always use the highest I can to conserve power. With blue and white and violet LED's, I have been able to get good results with as high as 7.5K, I believe.
grolschie
grolschie
Update: 4.7k's work nicely. Thank you all.  :)
earthtonesaudio
Before you put the LED in the pedal, you can check out various resistors on the breadboard.  Use the biggest value that still gives you enough light to save on power consumption.  Less current means less audible popping, also.
