need a wiring diagram for a switch
Started by ppatchmods, May 13, 2009, 04:38:18 PM
ppatchmods
anyone have a diagram for a 2 in 1 box pedal with a switch to switch the order the pedals are run in the chain? I have built 2 in 1's before but i want to be able to switch the chain order. i've seen it done and was wondering if anyone had a diagram or some insight. thanks
John
When your life is over, will any of this STUFF really matter?
The French connection
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
ppatchmods
interesting but not really what i was needing. that would be a cool project for a bench tester. thanks
MikeH
That's exactly what you need, just treat the send and return jacks like the inputs and outputs on your effects (or the switches that turn your effects on and off)
I do this in pretty much every twin pedal I make, and I've found that I almost NEVER feel the need to reverse the order of the effects on the fly, so instead of a stomp switch I just use a toggle.  And because you can actually see the position of the actuator when using a toggle (you know, "up or down") unlike a stompswitch, an LED isn't needed and you can just use a 3pdt toggle, rather than a 4pdt stomper.  Saves you 10 bucks or so.
There's an article on it at geofex; it's called "The Juggler"
ppatchmods
thanks mikeh and tfc. i get it now! i may be slow, but i'm worth waiting on.
john
My picture files:
ppatchmods
does it matter that i'm gonna use the same input/output for both circuits? I'm not doing them seperatly
ppatchmods
solderman
#9
Quote from: ppatchmods on May 13, 2009, 04:38:18 PM
John
Hi
This is exactly what the 42 is all about and a bit more in this tread
http://www.diystompboxes.com/smfforum/index.php?topic=76488.0
In there thers a link to both R.G:s juggler and beavisaudio.com OrderSwitcher that does the same.
Edit:
Ohh missed that those were mentioned earlier
//Solderman
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
