tone control Q
Started by enquiryband, May 15, 2009, 09:32:24 AM
enquiryband
if im adding a tone and volume control do i want to add it at the end of a circuit or the beginning?
The mark of an educated man; to entertain a thought without accepting it. Aristotle
bipedal
Typically they go at the end of a circuit...
IN --> CIRCUIT --> TONE --> VOLUME --> OUT
(BTW, here's a great tone control for adding at the end of circuits -- especially overdrives/distortions: Mark Hammer's SWTC.)
- Jay
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
Depends what you want it to do.  In the case of overdrives and distortions, the typical place for tone controls is at the "end" of the circuit.  One of the principal reasons is that high gain circuits tend to exaggerate any hiss sneaking in with the input signal, plus there are often harmonic components you don't want, and tacking the tone control at the end helps to manage both.
Of course, that strategy assumes the "tone control" is a treble cut.  If the intent is to have a different kind of tone control, then a different location may be in order.  For instance, while the Tube Screamer has the tone control after the clipping section, a much earlier model from Maxon had the exact same tone control before the clipping section, top produce a different quality of clipped sound.
In most instances, a volume control at the very end is the sensible thing to do, since it not only adjusts level, but keeps accumulated noise under control as well.  If the volume is inserted early on, then you have no way of taming any hiss or noise generated later in the signal path.
enquiryband
Quote from: bipedal on May 15, 2009, 09:39:24 AM
- Jay
is this the same one on the beavis A R site? http://www.beavisaudio.com/techpages/BigMuffToneControl/
earthtonesaudio
Quote from: enquiryband on May 15, 2009, 05:40:02 PM
- Jay
Not at all.
