535Q - ONLY LED - I killed another perfectly good pedal....
Started by stompbox steve, May 21, 2009, 04:36:32 PM
stompbox steve
Hello
I was just trying to add a LED to my 535Q, NOT looking to True Bypass.  (It is what it is and I have compensated for any loss and I am not looking to add another TB box :icon_wink:)
I am not sure how to attach a pix to this so here is a link: http://s6.photobucket.com/albums/y229/stompboxsteve2112/
Shown are my notes in trying to figure out what the leads are for the old switch.  Based on those findings I determined how I could wire a 3PDT (so I thought :icon_redface:).
It isn't working and wanted to see if this looked right before I continued on this path.
It seems like it should be working and maybe I shorted something?? which I will go back and hash thru.
ALSO: they inter-locked the PCBs inside so I had troubles getting them apart and hunted down a power source on the board, instead of tapping onto the main DC power.
Any comments are welcomed and appreciated.  Thanks, Steve
Funk it up,
Steve
aron
I don't see anything wrong in your diagram. It does look like true bypass to me as well. Use your meter and check continuity to the switch and board and jacks.
