Slacktave MKII question
Started by solderman, May 25, 2009, 03:03:06 PM
Fuzz Aldryn
Quote from: slacker on June 01, 2009, 03:57:57 PM
Looks interesting :)
I totally agree with that - looks like I definetly have to build another Slacktave. But I'm sure it will be worth and fun.:)
solderman
Quote from: solderman on June 01, 2009, 03:54:19 PM
Hi
I have been testing a fiev thing on the bread board and this is my latest mod. I have used 2 TL072 and used the 1:st and the 3:d op-amp stage on the first TL72 and the 2:nd an 4:th on the 2:d TL072. This is because of PCB layout routing reasons I wanted to test this setup. I don't know if this is the reason but I have found that the effect of the pots was minimal and narrow so I supst them for 4 SPST:s. one of them is the 3:d oct down (thank's Helge) Instead I invoked a "boostable" (trim pot) dry signal amd made the dry and effected signal separately mixable in to OUT. I also invoked a switch to kill the "clean" square signal so I can mix the  dry with the "only octave" Also supsted the 15K on op amp 1 to 33K to boost the signal that I found "choppy" I don't know why this is though but the signal chops and makes a terrible noise otherwise.
Hi
What looks good in theory does not always work IRL. When I bread boarded this one, I discowered that the gain was to low so I changed to a JFET buffer but for some reason that resulted in that the 4070 started to self oscillate I can't find why so I ditched the Ideé of a dry mix.
Q I cant get a descent oct down on q1(p12) q11 works just fine and is grate with q3 added. I use a CD4024BE. Does it have to be some particular CD4024Bx to get q1 to work. I have tried 4 different IC:s to roll out faulty components.
The only bad sounding stomp box is an unbuilt stomp box. ;-)
//Take Care and build with passion
www.soldersound.com
xSolderman@soldersound.com (exlude x to mail)
It should work with and CD4024 as far as I know, I've tried ones from two different manufacturers and they both worked fine.
The one octave down setting on mine isn't quite as stable as the 2 octave down, it sometimes jumps between the octave down and the fundamental but it's still a good strong octave down.
earthtonesaudio
A few posts back I think Rick (frequencycentral) mentioned feeding the counter with the output of the XOR gate; this way of doing x2, /2 will give exactly a 50% duty cycle for the fundamental, whereas taking the fundamental frequency output from the comparator directly may or may not result in 50% duty cycle.  Perhaps not noticeably different, but different still.
Might be fun to try both.  (Sym/asym mod)
earthtonesaudio
Thinking a bit more about the XOR stuff, there are 4 gates in there, so you could potentially get 4 octaves up and divide from there for a whole buncha square wave octaves.
solderman
#26
Hi
Her is a layout for the "Donkey Kong" Slacktave MKII+ mod.  made to fit in a 1590A, what else ;D
NOT VERIFIED (yet planing on building it on Thursday if I can find time)
PCB transfer
http://solderman.fatabur.se/Future%20project/Donkeykong.pdf
BOM
http://solderman.fatabur.se/Future%20project/Donkeykong.txt
www.soldersound.com
Quote from: earthtonesaudio on June 02, 2009, 03:04:07 PM
I did start to breadboard this last week, though I had issues with the fundamental extractor. But I had to clear my breadboard for my forthcoming 'Promiscuous Girlfriend' project, which is on a timescale. I'll get back to it soon, as I'm dying to try the wave shaping circuit I posted. Square waves are all very well and good, but sawtooths (sawteeth?) are FAT.
earthtonesaudio
Discrete XOR gate, for anyone interested:
http://www.ehobbycorner.com/images/discrete_logic_xor.gif  ...not ideal (adding gain/buffering at the end might be good), but better than nothing if you don't have a 4070 or 4077.
DWBH
#29
Has anyone tried a 4060 instead of the 4024?
Can something cool be done with the extra internal oscillator?
Just saw that the 4060 doesn't have Q1 nor Q2.
Quote from: DWBH on July 14, 2009, 01:02:08 PM
The 4060 has no Q1, Q2 or Q3 outputs, so the highest octave down it would give would be -4 octaves. Maybe suitable for communicating with humpback whales?
DWBH
Yeah, I noticed it (I edited my post) a couple of minutes later.
Bummer.
Quote from: DWBH on July 14, 2009, 01:34:03 PM
Bummer.
Oh yeah, I didn't notice you had edited until after I posted. Oh well, at least it allowed me to make the humpback whale wisecrack..................
I haven't tried but I think you can wire the CD4060 up in such a way that you can gate the clock , sort of like how an Uglyface works, that would probably sound pretty cool. Like has already been said though the lack of suitable output means it wouldn't be much use for guitar unless you multiplied the signal up first. A CD4040 would work in place of the CD4024, but it would sound exactly the same.
egasimus
Hey guys! Nut sure why I'm posting this, just felt like sharing. I've partially breadboarded an all-CMOS Slacktave. I'm using a 4069UBE and have the output stage and the 4024 divider built. It's currently fed by a 40106 oscillator, and plugged into a LM386 breadboard module. Obviously not done yet, and some things are still confusing, but it's nice to play around with :)
