rams head
Started by 1878, May 27, 2009, 02:11:50 PM
Hello Everyone
I'd like to build a Rams Head Big Muff. Am I right in thinking it's just the same layout as the other incarnations but with a couple of different component  values ??
Thanks in advance.
80k
Yep, you can use any Muff vero layout or the GGG PCB to do pretty much any version of the Muff.
I'd follow the schematic as you go along just to make sure. For instance, some boutique Muffs might use an extra capacitor or resistor which is easy to accommodate with existing Muff layouts or boards, as long as you follow the schematic.
