R.G.'s AB/Y box wiring, without the switches in a multiFX box
Started by sjaltenb, June 07, 2009, 10:13:08 PM
sjaltenb
http://www.generalguitargadgets.com/pdf/ggg_amp_aby.pdf
If i Dont want the switches, and want both outputs on at the same time, and Im not using LEDs...
I would simply wire the light green and maroon wires that come from the AB switch to ground...on the board just to the left of it.  Correct? And I would also simply wire the orange and black (input ring and sleeve) to star ground.
The rest would remain the same. Correct?
EDIT: Or..Maybe I dont have to connect anything...it just works as is...??
