ROG vero layouts need verification
Started by svstee, June 07, 2009, 11:03:15 PM
svstee
I drew up a couple vero layouts for some ROG pedals that I couldn't find layouts for, half to help people out and half to up my vero skills. I kind of suck at doing layouts, so can someone give these a quick once over and point out my glaring mistakes?
Just noticed that the trimpot doesn't connect to ground. That needs to happen.
svstee
Fixed the layout for the Omega, how do they look now?
ezanker
I only had a chance to take a quick look for now, but I think your jfet pinout is incorrect, should be D-S-G. Check the datasheet for your manufacturer to confirm.
Erik
ezanker
Also on the 3 legged dog you need a trace cut on row d somewhere between R7 and R3 (maybe you have one under C4 that I can't see?).  You also have a redundant jumper between rows i and j at columns 12 and 6.  They don't harm anything, but only one is needed.
On the pots, I believe the convention is that lug 1 is on the right when the shaft is down, so you might want to reverse the pot wiring on your layout if you want others to use it.
Thanks for sharing your work!
Erik
svstee
I never linked to the schematics on runoffgroove! Sorry about that,
http://www.runoffgroove.com/3leggeddog.html
http://www.runoffgroove.com/omega.html
Updated layouts
Thanks for the help.
