LED indicator wiring using DPDT
Started by caspercody, June 09, 2009, 09:47:15 AM
caspercody
Does anyone have a diagram showing how to hook up a LED when using a DPDT true bypass wiring? I wired my Thor up using the wiring shown on the Booster 2.5 (for the bypass), but not sure where to wire in a LED to indicate when the effect is on or off.
iaresee
You won't be able to switch an LED and your effect with a DPDT alone. But have a look at R.G.'s Millenium Bypass: http://www.geofex.com/Article_Folders/Millenium/millen.htm
caspercody
