DIP to ZIP conversion
Started by DWBH, June 16, 2009, 04:58:22 PM
DWBH
So I need to place a DIP IC where a ZIP IC is originally soldered.
Tough cookies, because they don't follow the same pinout/order. As in, pin 1 of ZIP isn't the same as pin 1 of DIP.
Only two pins share the same location.
The chip involved is a 41256 (Thanks Ron!!)
First I'll have to think on it on how am I gonna do it.
I've thought of making a little PCB, where pins 1 to 8 of DIP are organized in one side, and pins 9 to 16 are organized on the other side of the board. Other option will be to make a pcb for the socket, and then wire each pin one by one with.... wire.
The pcb of the original pedal IS double-sided, and traces can be lifted rather easily, so I can't mess with it too much
Here's where I'm at :P :
So yeah, leave your comment, insight, insult  ;)
Minion
I guess you can just solder leads from the pcb to a Dip socket and put the IC in the socket... You could make a small adapter PCB , I"ve done it so I can use 2 single IC"s in place of a dual IC ....
Go to bed with itchy Bum , wake up with stinky finger !!
mharris80
"People sleep peaceably in their beds at night only because rough men stand ready to do violence on their behalf"
DWBH
Yeah, small daughterboard is probably the way I'm going to do it.
I've searched for DIP to ZIP converters, but no luck.
