need to source some grommets or strain reliefs...
Started by trixdropd, June 16, 2009, 08:59:41 PM
trixdropd
I build some amp footswitch pedals utilizing ethernet cat-5e cable for the wire. I cannot find a suitable grommet to snuggly hold the cable into the enclosure, while also protecting the cable from the enclosure. can anyone point me to a suitable product?
I prefer something like this with a round hole...
trixdropd
Ripthorn
The only place I have found them online is at amp supply places like angela.com and tedweber.com.  They have different sizes so you should be able to pick what you need.  They are round rubber grommets at both places.
esnabez
I've used the Radio Shack rubber grommets for a similar application. I was happy with the results. Just use one that has a slightly smaller inside diameter than your cable's o.d., and they hold pretty snugly.
http://www.radioshack.com/product/index.jsp?productId=2103392
trixdropd
Thanks for the help fellas. i'll check all the links out.
As for the radio shack grommets, i have them, but it doesn't hold as good as I would like.
scratch
I've used the grommet solution as well, like you though the cable just slips through, so I put a loop in it and tie it down with one of these ...
http://www.thesource.ca/estore/Product.aspx?language=en-CA&catalog=Online&category=Clips&product=6408206
Denis,
Nothing witty yet ...
trixdropd
Quote from: tempus on June 19, 2009, 06:28:21 PM
http://www.allelectronics.com/index.php?page=search&search_query=strain+relief&x=0&y=0
I actually called them and tried all their connectors on an ethernet cable and said they had none that would fit snuggly. I order my plastic jacks for .33 cents a piece from them though, best deal i know of!!
I think I have a source for what I need now, I'll post it when I receive to know for sure.
punkin
Ernie Ball Music Man - JPM, THD Univalve, Grace Big Daddy, PepperShredder, BSIAB2, FireFly Amplifier.
trixdropd
Quote from: punkin on June 20, 2009, 05:01:10 PM
https://www.abra-electronics.com/products/product.php?productid=5068&cat=508&page=1
great link!! Thanks...  The only issue I have is knowing the right one to buy. i'm not sure the exact diameter of mt ethernet cable (cat5e). Can anyone hlep there? I have a micrometer, but need to learn how to read it...
punkin
sorry...no help there but I've used them before when they're too big for the cable, simply get a zip tie, wrap it around the cable on the inside of the enclosure...it won't get pull out. :icon_wink:
trixdropd
Quote from: punkin on June 20, 2009, 05:32:08 PM
Thanks for the tip and your help.. I appreciate it!!
