1uF caps for the BSIAB II: any that are a decent size?
Started by Bucksears, June 17, 2009, 09:41:14 AM
Bucksears
I'm building two BSIAB II's at the moment: one's a rebuild and the other is a new one that will incorporate AMZ's Presence Control/tonestack.
I've built these before, but all of the non-electro 1uF caps that I've found (needed for C3) are huge. Is anyone using electros for this one? Can that be done?
Or is it ok to use non-polarized electros for those, instead of film?
Thanks,
Buck
earthtonesaudio
Multilayer ceramics are tiny tiny tiny, cheap, and pretty good.  And tiny.
Bucksears
Quote from: earthtonesaudio on June 17, 2009, 10:09:33 AM
Yeah, but are they tiny? Thanks man, I'll look into those.
Heemis
If you're looking for a good 1uf film cap that isn't huge, I recommend the Panasonic 50v ECQ-V series.  The mouser part number is: 667-ECQ-V1H105JL.  These caps are very easy to fit into a layout that has space for a 1uf electrolytic cap... and they aren't overly expensive.
The French connection
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Bucksears
Quote from: Heemis on June 17, 2009, 10:38:55 AM
Thanks - those were back-ordered and I went with something else.
http://www.mouser.com/Search/ProductDetail.aspx?R=FK24X7R1E105Kvirtualkey52130000virtualkey810-FK24X7R1E105K
Hope these will work out - thanks everyone.
dschwartz
Quote from: Bucksears on June 17, 2009, 11:11:14 AM
I use those. Work like a charm and they are really tiny.
Tubes are overrated!!
http://www.simplifieramp.com
m-theory
QuoteIf you're looking for a good 1uf film cap that isn't huge, I recommend the Panasonic 50v ECQ-V series.  The mouser part number is: 667-ECQ-V1H105JL.  These caps are very easy to fit into a layout that has space for a 1uf electrolytic cap... and they aren't overly expensive.
Digikey carries these as well.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=P4675-ND
tackleberry
I got mine from small bear. http://www.smallbearelec.com/Detail.bok?no=168 They fit just take up little more room than the lower value box style.
