Vox 846 build not working. Wah sound stuck in one position.
Started by Chugs, June 23, 2009, 10:47:13 AM
Chugs
Hi, for my first ever build I built a veroboard 846 wah based on the Ulysses veroboard layout I found on this site. When I turned on the wah it goes but the wah sound doesn't wah. It sounds like it is stuck in the treble end of the sweep. I have checked the wiring to the pot is correct and even tried a different pot but with the same problem. Any suggestions as to what might be the source of the problem?
panterafanatic
is the board exact? have you googled other 847 schemes? i'm interested in building one as well. pic of the board? (both sides)
-Jared
N.S.B.A. ~ Coming soon
Chugs
I used a 56k instead of a 33k and a 2k instead of a 1.5K. Standard Q and mids mods but otherwise circuit exactly the same as the layout. I tried to upload a couple  of pics of the build by my camera has decided to stop working for no reason. Machinery has got something against me today. :icon_cry:
panterafanatic
mhmm. i have no idea. i'm pretty new to this. is it known to be a good circuit?
-Jared
Chugs
It's a verified layout so I guess so. VOx 846 wahs sound great.
Chugs
I got it working. I had the polarity around the wrong way on the battery snap. Doh! Sounds pretty good.  :icon_biggrin: Now I just got to figure out how to wire it up true bypass and I am good to go.
Paul Marossy
Quote from: Chugs on June 24, 2009, 11:21:30 AM
Hmm... that's interesting. I thought that it wouldn't have worked at all with the battery snap in backwards, but apparently it does.
Chugs
Yes, I wouldn't have thought so either. Consequently it took me a while to figure out that was the problem. I have it all wired up now in true bypass and it sounds great! MUCH better than the Vox 847A which I gutted to use as the shell.
I was going to install a Icar taper pot but I might try the trick of changing the 0.22 cap that feeds the wiper of the pot to a 0.33. Apparently this enable standard pots to mimic the old style taper. Anyone try this?
Paul Marossy
#8
QuoteI was going to install a Icar taper pot but I might try the trick of changing the 0.22 cap that feeds the wiper of the pot to a 0.33. Apparently this enable standard pots to mimic the old style taper. Anyone try this?
I haven't tried it, but please let us know how it sounds!
