Pedal Patch Bay
Started by azrael, July 08, 2009, 04:45:22 PM
azrael
I was gonna a build a patch bay like this:
http://guitars.musiciansfriend.com/product/Pedal-Pad-Patch-Pad-Guitar-Effects-Pedalboard-Patch-Bay?sku=500953#new
for my pedalboard, to make it easier to set up for gigs and stuff.
this is how i was planning on wiring it...
I think that would work properly.
But how do I ground the enclosure? Because if I don't, I'll end up with a fair amount of hum, right?
Any help would be greatly appreciated.
MikeH
I was just looking at the link- what is this thing supposed to do?
jacobyjd
It's basically just a bus station to put all your Guitar>Board and Board>Amp connections in an easy location. Looks like it has an A/B function too, for the guitar input.
Azreal: the jacks connected to the metal enclosure will ground it, so no hum.
FlyingZ
Ground the guitar input and keep the fx loop grounds isolated possibly with plastic jacks. I'm not sure about the amp out so isolate it to be safe.
trixdropd
Quote from: FlyingZ on July 08, 2009, 06:31:38 PM
Exactly. use metal jacks for all connection except amp footswitch in and out. make those plastic with isolated grounds.
FlyingZ
#5
I didn't see the foot switch jack, definitely isolate that.
DO NOT combine the guitar and effects loop grounds. It may work on some amps but absolutely not on others.
azrael
Quote from: jacobyjd on July 08, 2009, 05:20:59 PM
Exactly.
And perfect!
Quote from: FlyingZ on July 08, 2009, 07:57:58 PM
I thought the stereo jacks might be an issue. I read that in the MF link I posted...so I was wondering about that. How do I ground that? Just keep them from touching the enclosure? So...If I used something like nail polish on the inside of the mounting hole, and plastic washers to keep the jack from touching the enclosure? Or something like that?
thanks for the help so far guys!
jacobyjd
Good point.
Paul Marossy
Personally, I think each loop ground should be isolated. Otherwise you might have some potential problems with ground loops.
I'd be willing to bet that is how the looper linked above is built. It's using plastic jacks which isolates them from what appears to be a metal enclosure and I would guess that the grounds are only common for each loop, not all of them connected together. I've built some loopers before, and that is pretty much how I do it, too.
azrael
^But if I isolate them like that, how am I grounding the enclosure?
Still confused about how the stereo jacks..If they're isolated from the enclosure, they're still grounded?
trixdropd
Quote from: azrael on July 09, 2009, 02:59:57 PM
use letal jacks for your looper. This grounds the enclosure. For the fx loop jacks, use plastic, and don't connect their ground's to the chassis ground, just to eachother. Plugging a cabl;e from your amps loop into the pedal will establish amp ground on the loop jacks.
Paul Marossy
IMO, none of the jacks need to be grounded to the enclosure. The patchbay is just like an extension cord. You're simply plugging one cord in one end and another cord in the other end. As long as you keep the grounds together for each loop, everything should be fine. Just keep your wires as short and direct as possible, and twist each set of wires together.
azrael
You think twisting should be enough to shield them?
Paul Marossy
Quote from: azrael on July 11, 2009, 12:48:10 PM
Yeah. They're short wires an inch or two long.
azrael
Alright, thank you very much!
I'll drill the enclosure and report back with some pics, just cause. :)
FlyingZ
Personally I would and did ground the guitar only to the box.
Paul Marossy
Quote from: FlyingZ on July 12, 2009, 10:56:41 AM
It wouldn't hurt anything to do that. If I were to do that, I would probably do it on one of the FX loops instead, though.
