Decorating plastic enclosures
Started by destriaero, July 17, 2009, 10:20:51 AM
destriaero
Hey guys!
I have almost completed my first build - as common a fuzz face. Lot's of new learning - etched a pcb, debugging, etc.
Long story short, I went down to a friendly electronics store in Toronto and was searching for a reasonably priced enclosure. Found that a comparable stompbox size an aluminum Hammond was being sold as 20$, while a thick plastic enclosure was only $4.50. I think you know which one I bought. I obviously should've bought off digikey or something (I'm in Canada so stores like Small bear elec are a bit of a wait...), but I got burned before miscalculating the size I need and ending up with a matchbox sized enclosures.
Either way, Now I am wondering, is there any painting I can do on it to get it away from that boring black? Also how would I go about making labels for knobs.
Thank you in advance for all your advice!
Paul Marossy
They do sell spray paint made for use on plastic. Maybe you could look into that...
You might be able to drive over to E-Sonic and pick up a Hammond 1590b or whatever sizes you need. I believe they allow pickup not sure about a minimum order though.
http://www.e-sonic.com/acc/products.aspx?command=detail&partID=1590B&partIDExt=195
http://www.e-sonic.com/acc/locations.aspx
For best prices on Hammonds in Canada, Tip Top Electronics in Winnipeg, but it will be a bit of a wait. http://www.tiptopelectronics.com/home.asp?txtQuery=1590b
Last order from Small Bear took a week which isn't Digikey but is still really good for general mail.
Another option for a metal enclosure are electrical boxes from any hardware store.
dave
destriaero
#3
Thank you guys, will check out the spray paint and thank you so much for the links. I am always on the lookout for local suppliers :) On that note, if anyone has any more Canadian suppliers online or not, please do tell. I am thinking of making a compilation of stores in Canada.
How do all of you do your labels?
MikeH
The krylon for plastics work REALLY well.  It's designed to bond to plastic so it won't flake off like regular spray paint.
And another tip:  I works awesome on plastic knobs too
destriaero
Yay thank you! Going to go pick up a can tomorrow. Is there something I can use to give it more of a gloss?
Anyone do their own labels for pedals?
Top Top
They make glossy clearcoat spray as well.
deaconque
I've used the krylon fusion colors with their clear coat on a few pedals, works great.
Paul Marossy
Quote from: MikeH on July 17, 2009, 01:10:39 PM
Yeah, I think that's what I used in the past. It actually works pretty well.
