psychedelic fuzzzzzz!
Started by doug deeper, July 20, 2009, 06:01:52 PM
manolis
Ahhhh,The Music Machine....
IMO ,the Ultimate fuzztone sound, the sound that i am looking for years and still haven't found, is ......The Music Machine - Trouble.
Just listen to it and tell me what the ?#$? is this....
BTW i have the vinyl ''Bonniwell Music Machine - Ignition". Somewhere on the back it says "Keith Olsen - Bass,Vocals,Fuzz-Designer"!!!
It was 1966-1967.
Nah, you're all wrong.  It's this one, around the 1:50 mark   http://www.youtube.com/watch?v=b6jeQUbovjI
...or maybe this one, pretty much the whole way through.  http://www.youtube.com/watch?v=za1e_PEofdE
rnfr
Quote from: manolis on July 29, 2009, 11:31:31 AM
It was 1966-1967.
i've got that record as well- not on vinyl though unfortunately.  i need to get more of the early Music Machine stuff. Talk Talk is the jam!
petemoore
  http://www.youtube.com/watch?v=uquMUIC6GXY
  Hafta say the Holding Company knew well how to use Fuzz in a most gut-wrenching manner, works quite well against a backdrop of solid rythms made from fine artistry/musicianship.
  The Electric Prunes and Strawberry Alarm Clock made some interesting entries, fuzz w/tremolo and other 'oddities' in the mix.
  I find it's a bit hard to define psychadelic in music, Fripp did some flipp runs with King Crimson, 21rst Century Schitzoid Man...
Yeah, I think you win there.  Sam Andrew says here that they used Standell amps and Fuzz Faces: http://www.thepsychedelicguitar.com/andrew.htm
bluesdevil
Great job, Doug! Just got done slamming it on the breadboard and was not disappointed..... I could tell you put some effort into  finding the sixties "psych/garage" fuzz sound. I tried mucking about with the 47k that's coming out of Q2 to raise the fuzz volume more, but I then realized the mix is perfect as is. I think I'll save the trimmer and just throw a 100k resistor from output to ground... a true no-knobber!
       Thanks for sharing your efforts, looking forward to what you come up with next.
"I like the box caps because when I'm done populating the board it looks like a little city....and I'm the Mayor!" - armdnrdy
rousejeremy
Hey Bluesdevil, that was your 666th quote.
Quote from: bluesdevil on August 02, 2009, 10:27:26 PM
www.jeremyrouse.weebly.com
bluesdevil
Yeah, that is a landmark post for a devil!
brett
Hi
Given the feedback paths and various filtering in this, I couldn't "see" what the frequency response would be.  For example, the input cap would have to be filtering a lot of bass, given the low input impedance of the PN2222.  But how much?  So I did a bit of LTSPICE ing and found (if I did this right) that this circuit has a quite large hump in the upper mids (500 to 1kHz).   100 Hz is about 10 dB down and 10kHz is 15 dB down (deep down!).
Here's the AC analysis.  http://www.aronnelson.com/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=40187&g2_serialNumber=1
Brett Robinson
brett
Hi
although this is a simple project, I thought I'd knock together a PCB.  Here's a tiny PCB that mounts on the volume pot.
There's what it looks like:
and the PCB
Brett Robinson
GREEN FUZ
You read my mind. I`ll have to build it now.
SpencerPedals
I'm a fan of the Companion circuit but it's not on my breadboard at the moment...anyone put up a soundclip to see how it compares?
doug deeper
Quote from: rnfr on August 07, 2009, 04:23:32 PM
i made a vintage style vero layout-  it's on my blog.
http://apocalypseaudio.blogspot.com/
tell me about the "wem hand full" on your site!
do you have a link with anymore info? do you know what it is?
freakout and psychedelia buttons!
wylde!
rnfr
Quote from: doug deeper on August 08, 2009, 09:33:46 AM
wylde!
doug, i wish i knew more, too!  that thing has always been a mystery to me.
WhenBoredomPeaks
For me it sounds like a boost on the lower frequencies and a fuzz on the high frequencies blended.
Amirite?
doug deeper
you are, single notes work best.
its only good if its what you're looking for!
i for one love this sound!
LucifersTrip
Quote from: doug deeper on July 22, 2009, 11:49:07 PM
music machine
http://www.youtube.com/watch?v=jJR_KGZO4U0
a little closer to some of there other tunes though, this ones a little raw.
i'll definitely try yours...and thanx again for the 22k suggestion to the right of the 350k on the fuzzrite
http://www.youtube.com/watch?v=aEEi2FvptSw&feature=related
always think outside the box
LucifersTrip
Quote from: petemoore on July 30, 2009, 02:01:20 AM
I have to throw in my vote for the almighty Cucumber (love this straight thru but it's brutal at the :58 mark)
http://www.youtube.com/watch?v=0xY20Ec56ag
and  Ron Wray:
http://www.youtube.com/watch?v=IXLG1KgKbHg
honorable mention:
http://www.youtube.com/watch?v=MNQewqen1LA&feature=related
