bass guitar booster + tone stack
Started by craigmillard, July 24, 2009, 09:02:07 AM
craigmillard
Hello All ;D,
I am looking at creating a bass guitar boost pedal with a tone stack maybe the mini-booster + amz presence tone stack 2?
What do you all think, or any suggestions on something more suited to the bass guitar? i cant find much regarding bass guitar effect building or converting??
Cheers
Derringer
I had good results just using a simple JFET gain stage
play with the bypass capacitor ... I liked caps between 1 and 10 uf to accentuate frequencies
Ben N
#2
FA-1? Leave out the bass-cut switch and maybe tweak some values to shift the center of the Baxandahl down an octave or so. This should be cleaner than a minibooster--if that's what you want. If you are careful about the ratings of your components you could probably also run it at higher voltage to get more headroom.
boogietube
Try the flipster. It says it's a distortion box, but not really. There are a lot of useful clean tones and overdriven tones there, and it has a tone stack. Keep in mind that not one clip I have heard does justice to it.
Pedals Built- Morley ABC Box, Fultone A/B Box, DIY Stompboxes True Bypass box, GGG Drop in Wah, AMZ Mosfet Boost, ROG Flipster, ROG Tonemender, Tonepad Big Muff Pi.
On the bench:  Rebote 2.5,  Dr Boogie, TS808
boogietube
Derringer
gro'o've
the extra 'o' is for "OOOhhh that sounds good !!!"
;D
rbstep
doitle
It doesn't have a tone control but one could certainly be added:
LPB-1
I just built one a few days ago and changed the input and output caps to 4.7uF Electrolytics. I think it sounds pretty awesome with a bass.
Minion
I just finnished designing and building an active preamp with Bass/Treble controll and a gain controll for my Bass guitar, it actually fits inside my Bass guitar .... It turned out pretty good , a bit too much gain in the second stage but it is good for going from a clean sound to an overdriven sound ....
it is basicly a 2 opamp stages with a passive tone stack in between and adjustable gain on the second stage ... I can share the PCB design if you want , it is only 2.5in x 1.5in ....
Cheers
Go to bed with itchy Bum , wake up with stinky finger !!
craigmillard
Cheers for the responses all!!
Think im going to have a play with the fa-1, but try the Bandaxall values of the flipster maybe? Bit of breadboarding till i get the sound i want!!
Anyone else tried the fa-1??
