Why use a 0 ohm resistor?
Started by Taylor, July 30, 2009, 01:16:51 AM
jacobyjd
Quote from: JOHNO on July 30, 2009, 12:25:17 PM
Yeah i dont get all the hoo haa with jumpers. if you hand wire a circuit point to point its just like using all jumpers isnt it? And they call that "Mojo". but stick a jumper in a circiut board and its some kind of sin.
I think the issue is mainly regarding pcb design, especially in the case of a commercially-produced electronic circuit--a jumper adds parts and labor cost that can really add up on a large-scale basis, but can be avoided by better PCB design.
So in essence, if a circuit has 2 jumpers and they cost $.05 in extra parts/labor, then you're talking $.10 extra in cost.
Now multiply that by 10,000 or 1,000,000 and you see a significant cost increase.
stibu
0 Ohm resistors are easier to manually insert and necessary for auto-insertion. This makes them cheaper in the long run than regular jumpers.
They are particularly useful when the board was laid-out for a resistor and you have changed the design such that the resistor is replaced by a short. Rather than spin another board just to fix this, you can populate it with a zero ohm resistor. A life saver if a thousand PCB's were fabricated.
Solidhex
 I use 0 ohm resistors all the time. Of course I try to do my layouts without jumpers but in certain circumstances they help a lot. Cutting wire then stripping the insulation to fit the jumper sucks. I just grab a 0 ohm, bend the leads an stick it in.
--Brad
Paul Marossy
Quote from: Solidhex on August 02, 2009, 04:43:16 PM
--Brad
I don't use wires. I save the clippings from resistors and capacitors for things like using them as jumpers. Much easier.
Taylor
Quote from: Paul Marossy on August 02, 2009, 04:54:10 PM
Yep. Although "saving them" in my case amounts to rarely cleaning them off my desk.
I'm still not seeing a compelling reason to use 0 ohm resistors, for me, but everybody's got their preferences.
Paul Marossy
Quote from: Taylor on August 02, 2009, 05:24:13 PM
I have a little drawer that the clippings go into after I am done with a project. My workspace is multi-functional, so I have to keep it clean.  :icon_wink:
therecordingart
Aside from automated building....I'm just throwing this out there....
If there is a problem in a circuit the 0hm resistor may burn up stopping any point after that from being affected? I imagine it'd take a hell of a lot of electricity to burn up a leg from a resistor being used as a jumper.
JKowalski
It would take a hell of alot to burn up a resistor package, too.
The things you are referring to are called "fuses"  :icon_biggrin:
In low voltage electronics, you typically don't need those.
Radamus
I was thinking that the 0 ohm resistor might give you a decent anchor point for making a connection. Say you're perfboarding and you have to connect two legs of an IC together. A wire jumper takes up more space if you're imprecise at cutting them (like me), and using a leftover piece of wire has no anchor, so it can wind up sticking to your soldering iron, rather than staying where you leave it. Having never used a 0 ohm resistor myself, I don't know, but when I saw one in one of the cry baby's I've opened, it was a tempting option. Maybe my skills just lack.
