valvecaster current draw
Started by bagudan, August 04, 2009, 04:05:13 AM
bagudan
Hi. Planning on douing a valvecaster with internal regulated powersupply... cause I have trafos lying around. Will a 15 v 120 ma transformer do?
Kasper
Too low - the heater alone of a 12au7 draws 150ma. At 120ma all it will do is hum.
bagudan
ok...thanks... these cheap-ass trafos are of no use:)
Having said that, a Valvecaster won't draw too much over 150ma in total - the plates draw very little current, it's the heater that's greedy. I bet you'd get away with 200ma.
bagudan
supeer... maybe I have one of those?
kurtlives
Quote from: frequencycentral on August 04, 2009, 05:00:06 AM
Pretty sure they draw 300mA when hooked up the way they are in the VC. I am actually certain it is 300mA.
My DIY site:
www.pdfelectronics.com
Quote from: kurtlives on August 05, 2009, 03:28:43 PM
12AU7 data sheet says different: http://frank.pocnet.net/sheets/127/1/12AU7.pdf
Series (as in the Valvecaster): 12.6v @ 150ma
Parallel: 6.3v @ 300ma
kurtlives
Ah that's right. I wired mine in parallel.
My DIY site:
