Clipping arrangement
Started by newfish, August 10, 2009, 10:51:39 AM
newfish
Hi All,
Was playing around with some clipping the other day and discovered the following arrangement...
'Send' side (diode towards ground).
Signal in from booster -> 2K2 Resistor -> Ge Signal Diode -> 220nF Cap -> Ground   ... and on the 'return' (from ground back to the output signal)...
220nF Cap -> Ge Signal Diode -> Signal from booster.
Both Diodes at the 'ground' end are connected together, *then* go to ground through the cap.
This gave a distinctive sort of sound - quite different from the usual Symmetrical / Asymmetrical arrangements.
Just wondering if anyone else out there has tried this.
Happiness is a warm etchant bath.
bipedal
Have not tried this.
You noted "distinctive sort of sound" -- in a good way?  Any sound clips?
Am curious on the function/effect of the cap there...
"I have gotten a lot of results. I know several thousand things that won't work." -T. Edison
The Happy Household; The Young Flyers; Derailleur
dschwartz
you´re basically clipping frequencies above 330hz (2k2, 220n low pass filter).. should give you a less buzzy clipping with cleaner low end.
you can make the same with only 1 cap between the diodes and ground.
Tubes are overrated!!
http://www.simplifieramp.com
Joe Hart
Could you put a pot (like the input cap blend from the Easy Face) and have a kind of "fine-tuning bass frequency flabbiness" knob?
-Joe Hart
newfish
I guess so.
You could call it 'Cellulite'...
:icon_eek:
