Jacks grounding
Started by tomtom, September 26, 2003, 07:47:58 AM
tomtom
Just a silly question, I use some sort of star grounding for effects were nodes (read: group of earth points) where connected to one point of the circuit (power capacitors ground). The Jacks are isolated each ground are connected to their earth point (input and output).
 That's mainly for big effects or tube stuff, so I wonder how you connect yours jacks grounding points (some old EH stuff do not solder anything to the output jack ground, maybe using chassis as a ground plate) and if you use to wire the box (aluminium hammond) to the circuit ground (like a shielded cable).
 Thanks.
 Tom. :roll:
aron
QuoteThat's mainly for big effects or tube stuff, so I wonder how you connect yours jacks grounding points (some old EH stuff do not solder anything to the output jack ground
I aways solder to the jack ground tabs. I know you can get away with not doing it and using the box as a ground directly - but I've seen the jacks get loose too many times to depend on that.
tomtom
Thanks Aron
 I was wondering about using one wire from the board to both jacks, it seems easier to wire but that's a ground loop (bad !).
 Does "boutique" (or whatever names that fit) and "big diyers" use one wire from board to ground (lot less wire, more if you use that wire for pots grounding lugs) ?
aron
Quote from: tomtomThanks Aron
They might use two wires; one for each jack.
The currents are so low that I don't think the loop affects the pedal.
tomtom
Andy
I posted this topic the other day.  Read the posts.  it might give you some ideas.
http://diystompboxes.com/sboxforum/viewtopic.php?t=766
Andy
tomtom
