simple a/d to d/a circuit using cheap stuff. how do i start?
Started by big bustle, August 29, 2009, 01:33:10 AM
big bustle
so i want to build a circuit that has an a/d to d/a conversion.
i'd like to specifically add really bad digital audio artifacts to the signal so i'd like a chip/chips that can operate at 6 bit or 4 bit resolution that hopefully don't have input filters to get lots of aliasing
how do i start?
i found the tlc549 chip from ti.
says it samples at 8-bit blah blah blah
how do i connect that to a d/a chip and get some output?
i know the tlc549 is an 78-bit but after hours of googling it all i found
http://focus.ti.com/docs/prod/folders/print/tlc549.html
i don;t know where to start with this stuff
i read the stickies at the top of the forum and while the links are full of theory i don't know what connects to what.
Blue_Toad
Hi fucdemas,
I might be able to help but I need to understand what exactly you're looking for, I'm guessing you're looking to do something like this.
A/D (Making a bunch of aliasing) -> D/A
with nothing in the middle right?
big bustle
hey blue
QuoteI'm guessing you're looking to do something like this.
that's pretty much the basic idea for now
if anything a basic primer on digital circuits for audio would be nice.
i assume there are standard frameworks that have been used and many devices are interchangeable.
i was placing an order with futurlec and decided on a whim to buy a TLC7524CN dac
(while googling i found this link which seems to be an entire course on DSP construction)
http://www.ece.unh.edu/courses/ece649/documentation/index.htm
and this: and aTLC549CP ADC
i was going to look at the data sheets and just see what happens when i connect the 2.
i figured it was a place to start :)
i do need to find chips that sample at a really low bit rate or have adjustable bit rates. i google while the other day and found nothing
Blue_Toad
It's a good place to start, as long as you get the CS and WR lines right it will pass through the AD and into the DA, without a low pass on the output of the DAC there will be a little high end distortion but other wise should be basically a pass through as long as you hook it up basically like the notes later in the data sheet.
If I can help, let me know,
BlueToad
big bustle
MoltenVoltage
analog devices sells some sort of bit reducer chip that i've been meaning to order
if you've never checked out bug brand stuff you should - he makes some really cool bit reduction things and posts (or used to post) schematics for everything
MoltenVoltage.com for PedalSync audio control chips - make programmable and MIDI-controlled analog pedals!
alanlan
You could also consider using A/D and D/A with more bits, say 12 or 16 and then having switches to disable certain data bits to really screw up the signal.
big bustle
ok so i'm back on this project.
i am at a loss on how to connect these two chips
my ad is the tlc549cp
datasheet: http://focus.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=TLC548
my dac is the tlc7524cn
datasheet: http://pdf1.alldatasheet.com/datasheet-pdf/view/28932/TI/TLC7524CN.html
i found this article on how to interface the tlc549 to the msp430
http://focus.ti.com/general/docs/litabsmultiplefilelist.tsp?literatureNumber=slaa112
this seemed like a good place to start to figure out how to do this. i wired up the tlc like this but couldn't figure out what the DAC needed.
here's an image for anyone that would like to use mspaint to show me how to get these things to work.
alanlan: if you could point out how to wire switches to mess up the signal that would be awesome
free electron
The problem is, that TLC549 is a serial output ADC with SPI interface, where TLC7542 is a parallel input DAC. You can't connect them directly. You'd need some additional logic to convert the serial SPI signal into the parallel bit representation (shift registers).
You need  a parallel output ADC and parallel input DAC to get them work connected directly. Then you could also do some bit messing with the switches.
Here's the idea:
big bustle
Quote from: free electron on November 18, 2009, 03:33:26 PM
Here's the idea:
wow thanks for the tip! the whole digital world is just one big mess of confusion for me! the more i read the more questions i have. i might order these chips and go from there.
