Boss Metal Zone malfunction Advice?
Started by budkingston, August 29, 2009, 02:21:24 AM
budkingston
I have a Boss Metal Zone that has failed.
The bypass works fine, but when the pedal is in use, the sound is cut to 1/10. I can hear it working, if I am against the amp. All knobs function and light comes on. It is just anemic.
Pedal is 2+ years old, covered by warranty (useless actually because it only covers parts after 90days!)
Does this sound like something that can be fixed easily? Should I just junk it? or is there a "recycle service" for these?
Paul Marossy
My first two guesses would be the little momentary bypass switch or something might be wrong with the FET flip-flop circuit.
I would suggest building an audio probe and tracing the signal path. Start at the bypass switch and the FET flip-flop circuit. I have a hunch that's probably where your problem is likely to be.
budkingston
Quote from: Paul Marossy on August 29, 2009, 12:12:42 PM
I can actually make that and I have the skill to do it, at least if there is some instruction. Do you know where I can find a schematic that has the signal train?
budkingston
Paul Marossy
Glad to be of some help to you. Hopefully you can get this thing figured out!
