Which lug does what in this slide switch?
Started by nosamiam, August 31, 2009, 04:03:25 PM
nosamiam
I am looking at this datasheet and trying to figure out what does what. I know how switches work in general, but I've never seen the symbol at the top of the page.
Can anyone help?
http://www.cwind.com/SwitchPDFs/Catalog2/ssG338S.pdf
Just curious - do you have an ohmmeter?   :)
MoltenVoltage
I actually bought a bunch of those when I first started building - switched to rotary switches which I like much better
The two adjacent lugs are connected when the switch is in a particular position - there are four positions and 5 lugs per side
position 1 - lugs 1 and 2, position 2  - lugs 2 and 3, etc.
I have a bag full of probably 20 or so if you want to buy them - just PM me
MoltenVoltage.com for PedalSync audio control chips - make programmable and MIDI-controlled analog pedals!
nosamiam
Quote from: R.G. on August 31, 2009, 05:16:10 PM
Guess I should have clarified my purposes a little. Yes I have a couple of meters, but I don't have the switch in question in my possession. I've started working on a PCB mount layout and am not ready to place my parts order just yet. I figured I could get a head start if I could get the pinout ahead of time. No worries  ;)
Quote from: MoltenVoltage on August 31, 2009, 05:26:25 PM
Thanks for the offer. I don't think I want any more than this one. They look like kind of a pain, but for this build I'm doing it all PCB mount and rotary takes us too much real estate and the height is steering me away.
Anyway, thanks for the help. I guess my real question is: Which pair of lugs are common (input)? Are they on one end? Or in the middle somewhere?
Taylor
#4
I think it doesn't work like that - no common pole. As MV says above, the first position connects lugs 1 and 2, then the next position connects lugs 2 and 3, then 3 and 4, then 4 and 5. If you wanted to wire this as a SP5T, you could connect all 5 lugs on one side together as your input, then connect the 5 lugs on the other side to your 5 things you need to switch.
Don't know what you're doing, your setup, etc, but I find that cutting and filing a slot for a slide switch is way more of a pain than dealing with rotaries. JMO.
nosamiam
Quote from: Taylor on August 31, 2009, 05:59:08 PM
Well ok! Rotary it is! I'll just do it offboard. As for what I'm doing... it's a Gristleizer. If it works out, I'll post the build report. It's gonna be a while though. Good-sized circuit, w/ rotary sw + 5 pots, charge pump, & Millenium bypass...  in a 1590BB, maybe.
Thanks for the help folks!
