transferred layout to vero board, images uploaded, anyone see anything wrong?
Started by dimebagslash123, September 03, 2009, 08:58:42 AM
markeebee
Josh, if you really don't know who it is, you are in for SUCH a treat......check this......officially the most famous artist in the UK.....
http://www.youtube.com/watch?v=GS-itkO9ia8
There is NO substitute for genius.
dimebagslash123
ok so iv soldered pin 3 to 5 and the gain is no longer controlling the volume.... it doesnt do anything lol, volume works but is a bit quiet and geting plenty of static lol
markeebee
Have you cut the track under R7?  Can't tell from the vero layout.
markeebee
There's a bit of a conflict between the schematic and the PCB layout.
Not sure whether pin 5 should get it's supply from the nominal 9v bus, or from point Vcc.
Anyone?
dimebagslash123
just to confirm that the track under r7 is cut, cheers, any other ideas?
Electric Warrior
Quote from: markeebee on September 03, 2009, 12:29:41 PM
Anyone?
pin 5 or pin 8? I can't see any conflicts.
markeebee
Yeah, sorry, it's alright.  Pin 5 goes to nominal bus, pin 8 goes to Vcc.  It's alright.
I was still badly shaken by my experience with your avatar pic when I posted that.
dimebagslash123
hmmmm strange, volumes working (doesnt go very loud) gains now doing nothing since i soldered pin 3 to 5. although it was only altering volume before anyways? lol, gota go out to a gig but will check up when i get in tonight, thanks to everyone for all the time they have/are still putting in
The French connection
How did you connect pin 3 and 5? through a wire over the IC or with two jumpers? If you use 2 jumpers, maybe you have to cut a track around R6...Also Did the strip ''i'' become a ground or not? 'Cause if not you have a 1M resistor connected to your gain pot and and all those component that are supposed to be ground are not grounded yet...Or i'm confused!
Dan
I know, but the pedal i built does not boost...it just increases volume!
My picture files:
http://www.aronnelson.com/gallery/main.php/v/French+connection/
http://s193.photobucket.com/albums/z4/letournd/Pedal/
Electric Warrior
Quote from: markeebee on September 03, 2009, 12:59:06 PM
what's wrong with my avatar pic?
jacobyjd
Quote from: markeebee on September 03, 2009, 12:06:43 PM
Here I thought that was you.
Wow.
...makes me wish I had a picture of someone cooler in MY av.  :icon_razz:
markeebee
jacobyjd
markeebee
Quote from: Electric Warrior on September 03, 2009, 01:45:18 PM
Oh, sorry, sorry, sorry.
I thought it was some rockstar person or something, didn't realise it was you.  I 'm embarrassed about asking now.
Oh look, it's raining now, must go.......
dimebagslash123
hi, i is ground as its got a wire from c which is ground, and 3 to 5 is done by a wire on the reverse of the board, so c, i , and g are now ground and pine 3 and 5 are connected with a wire on the soldered side of the board (on the ic socket legs) all the jumpers are wires from point to point
dimebagslash123
holy crap hang on, as the vero layout is an altered version of ov somesones elses on here, where the jumpers are on the diagram......iv just put one wire from one end to the next....do they all need connecting along the blue line?
markeebee
